Old 07-03-2005, 10:53 AM
BlueGrot  is offline
Posts: 132  -  iTrader: (1)
Talking
Re: Ibanez 8 string???
Yes, I wouldn't get to sleep if I didn't.
Old 07-04-2005, 05:10 AM
Papa_Shank  is offline
Posts: 126  -  iTrader: (1)
I've seen the shorter video of that that doesn't get far enough to mention the scale, he doesn't sound all that sure about the scale but I'll go along with what he said
Old 07-04-2005, 09:02 AM
Tsorovan  is offline
Posts: 260  -  iTrader: (0)
I wouldn't trust Hagström's word in this, actually.
Old 07-04-2005, 09:26 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Originally Posted by Tsorovan
I wouldn't trust Hagströms word in this, actually.
Why?
Regards
André
Old 07-04-2005, 05:14 PM
ibanezrocker61  is offline
Posts: 289  -  iTrader: (1)
that makes no sense.. no one else would know the "contents" of that guitar but him and Fredrik, its a 32".
Old 07-04-2005, 11:05 PM
Tsorovan  is offline
Neither Fredrik nor Mårten are very into guitar specs or stuff like that (they don't care that much), and both have been known to supply contradictory info in the past.
So no, I wouldn't trust that blindly. I'm not saying he's wrong either.
Old 07-07-2005, 03:42 PM
ry4n  is offline
Posts: 47  -  iTrader: (0)
id trust him on that. btw its 30" (him being Tsoro)
Old 07-11-2005, 01:16 AM
Barking Pumpkin  is offline
Posts: 5  -  iTrader: (0)
I think some people are giving Meshuggah a bit too much credit. They basically just play really low and chug chug chug in start/stop rhythms and time signatures. This is the formula for a whole lot of their songs, and they can get rather monotonous. I could name several other bands that are more complex and more interesting to listen to.
Old 07-11-2005, 04:57 AM
ry4n  is offline
you should try to listen to DEI or Fredrik's Sol Niger Within... less chug, more thoughtful guitar.
Old 07-11-2005, 05:09 AM
I had heard about Fredrik Thordenal's Special Defects.....sounded interesting.
Old 07-11-2005, 06:56 PM
NiMH  is offline
Posts: 3  -  iTrader: (0)
Originally Posted by Jemmm
Please have a look at the following pics of this Ibanez 8 string....
[IMG]image removed for space purposes[/IMG]
Compaired to regular RG-7 you can see the upperhorn swoop to be a little less deep/wide than normal RG swoop.....
But the neck.....and this is what's bugging me. The neck looks almost like regular RG-7 neck. I mean, it's not huge like the 8s I have seen from others (LGM et al.)
Seem the string spacing is more compact......
Not even asking where he might have gotten that top-nut and trem, cause bet they are custom jobs.
Yeah, Meshuggah has those custom made. As far as the neck specs, I think it's a little wider than a wizard-7, you can tell by the locking nut...there are four blocks as opposed to a seven-strings normal three. To see more of Meshuggah's eight strings, go to www.nevbornguitars.com and check out the Sliepner I and the Sliepner XL (designed for Meshuggah).
Old 07-12-2005, 01:05 AM
Tsorovan  is offline
Erm. It just looks that way because... the necks have a longer scale.
And Ibanez 7s have 4 locking nut block screws (the middle block is a "double block").
The string spacing on the Ibanez 8s is definitely the same because the bridge is manufactured from two fixed Lo-Pros (as on that Dino Cazares guitar) cut in half (well, not truly in half, but 4 saddles from each).
Old 07-12-2005, 05:54 PM
ry4n  is offline
Tsoro you should bust out those close-up images of the 8's Fredrik sent me. I cant find them on my puter, maybe you still have em?
Old 07-12-2005, 06:18 PM
the string spacing is the same as any other guitar.. 6 strings, 7 strings.. this one just has that magical 8 strings
Old 07-12-2005, 06:20 PM
i dont think ibanez actually cut fixed lo-pro's in half.. they just manufactured an 8-string one the same way the would for a 6 or a 7 string one.. they obviously have the machinery to do so.
Ibanez Doubleneck 6&7 String jemaholic Other Ibanez Guitars (including Premiums) 11 09-30-2004 09:25 PM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 10:44 PM
