Old 04-07-2002, 10:58 PM
generalhammond  is offline
Posts: 27  -  iTrader: (0)
Ibanez hard cases...
What is the standard hard case for an RG 7xxx? Is it the M100C?
Old 04-07-2002, 11:02 PM
Rich  is offline
Posts: 19,345  -  iTrader: (21)
UV1000 for all RG type 7 strings.
Old 07-17-2002, 04:50 AM
Dylan7620  is offline
Posts: 636  -  iTrader: (1)
would an m100c fit a 7? or is it still too short? i like that case better
Old 07-17-2002, 05:01 AM
Rich  is offline
Just BAREly, but, any decent shot on the headstock end can snap the head. Not recomended.
Old 07-17-2002, 05:13 AM
yikes. ill go for the greater cause, thanx
Old 07-25-2002, 10:39 AM
Wound  is offline
Posts: 312  -  iTrader: (0)
Damn...when I got my RG 7421xl I ordered a case for it. Since none of the cases instore where I got it from could fit the neck, the guy I know there rang up the Ibanez importers here (Australia), and they told me that I had to get the M100C, they said it has been modified now to fit all 7 strings so that normal 7 strings have alot of space for the headstock and the xl less...so is this not true?
Old 07-28-2002, 12:36 AM
naw dudem i tried one with a 7420 at GC, it didnt fit, maybe it was an old one er somethin but it didnt fit the regular 7 neck
Old 07-28-2002, 12:39 AM
Rich  is offline
You have to remember there are 2 different M100c's. A 7 will "just" barely squeeze into the US version, since it doesn't need to, they didn't design the US version for it, we have the UV1000. The offshore M100 may have just a little more room designed into the headstock end. The ones I have are burried so I can't test it right now.
Old 07-30-2002, 11:14 AM
Wound  is offline
I believe Australia imports all Ibanez products from America so it would be the american case.
I emailed AustralisMusic today (the Ibanez importers here), they said that the case has been modified now to fit all 7 strings since there has been so much trouble with it in the past...I hope they r right heh, I'm pretty worried cause I need this case to fly my guitar to Norway and orders from America takes like 3 months...so by the time it gets here I will have to leave fairly soon and will not have a chance to order a UV1000. Well I have asked em twice now so they better eb right...
Kim
Thanx for ur help guys
Old 07-30-2002, 01:15 PM
GhesQi J  is offline
Posts: 221  -  iTrader: (0)
There are indeed two different M100C's. (At least here in Belgium).
When I asked my local guitar dealer an M100C hardshell for my seven string, we trial-fitted my axe in a 'normal' M100C case. It didn't fit (unless pushing the foam at the headstock)
So I ordered a so called 'M100C hardshell for seven strings'. This case looks exactly the same as the 'normal' M100C, but is slightly longer.
My RG7 went in like butter..
Cheers,
Joten
Old 07-30-2002, 04:54 PM
Rich  is offline
Kim
Australis deals directly with the factory in Japan, they do not import from the US.
Old 08-01-2002, 09:52 PM
Wound  is offline
Oh...strange...both Ibanez guitars I got from there had to be shipped from America heh...doesn't matter...I just hope my case fits...
ibanez guitars
