Other 7-string Guitars
Insane guitar
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
Page 2 of 14
02-15-2007, 12:03 PM
crevis
Posts: 2,599 - iTrader: (
Re: Insane guitar
Jemwielder
Stone.... Really? The whole thing? Perhaps you should consider just having the top have a layer of stone? Also I think stone would sound really crappy. It's molecules are way too rigid. Wood is flexible and resonates that's why it's the industry standard. If you want to try this go ahead. You're going to be disappointed though.
Anything with a rigid molecular structure will resonate well whereas wood will absorb the vibrations. I can imagine this being a feedback monster.
crevis
Find all posts by crevis
02-15-2007, 12:46 PM
The Euphor
Posts: 2,947 - iTrader: (
Re: Insane guitar
NAMM 1998 - 2003. I am quite sure somebody presented a stone guitar at one point. No names or anything, but I think they only made part of the body from stone.
Good luck! Would be nice to see the result!
The Euphor
Find all posts by The Euphor
02-15-2007, 09:43 PM
Dee
Posts: 8,514 - iTrader: (
Re: Insane guitar
How about stone with hollow chambers inside? You'd have to make the
guitar body
in two halves then stick them together, but maybe that'd work? Interesting project, I'd love to see how it will turn out if you can do it.
Dee
Find all posts by Dee
02-16-2007, 03:02 AM
Lefty Robb
Posts: 4,930 - iTrader: (
Re: Insane guitar
44lbs....
Lefty Robb
Find all posts by Lefty Robb
02-16-2007, 04:17 AM
crevis
Re: Insane guitar
Dee
How about stone with hollow chambers inside? You'd have to make the guitar body in two halves then stick them together, but maybe that'd work? Interesting project, I'd love to see how it will turn out if you can do it.
And what do you stick stone together with? Bolts?
crevis
02-16-2007, 04:39 AM
Dee
Re: Insane guitar
Yes, if they are countersunk, otherwise cement?
Dee
02-16-2007, 04:54 AM
smoovyb
Posts: 8 - iTrader: (
Re: Insane guitar
I read this in a guitar magazine awhile back. Henry Garza (the guitarist from Los Lonly Boys) was having a statocaster built for him with a stone body. The body was still made out of wood, but laminated in stone. I remember him saying that it improved the tone. I'm guessing that it would sound really "mid-rangey." But I've never played one so I wouldn't know.
smoovyb
Find all posts by smoovyb
02-16-2007, 09:04 AM
dannymills
Posts: 1,398 - iTrader: (
Re: Insane guitar
How the hell do you laminate something in stone!?!?!?!?!?
dannymills
Find all posts by dannymills
02-16-2007, 01:07 PM
komorok
Posts: 69 - iTrader: (
Re: Insane guitar
I made the first cuts today. Just a wide cut to prepare the fitting of the reinforcement. So here we go.
As an answer to the short discussion about joining two stones together: First you drill holes in the stones, then you put something in the holes, like bolts. Then you will use a special stoneglue. That will make the joint as stable as anything!
I looked the NAMM thing up. NAMM 2005. It happens that a company puts a thin stonelaminate on the front of their guitars.
komorok
Find all posts by komorok
02-16-2007, 02:39 PM
smoovyb
Re: Insane guitar
dannymills
That is an excellent question!!!!
smoovyb
02-16-2007, 02:49 PM
RCB
Posts: 1,598 - iTrader: (
Re: Insane guitar
Aside from the fact that its going to weight too much, you ll find out that it will (most likely) sound VERY bright and thin. It will probably have huge sustain though. IMHO a very thin 2mm top (over mahogany or a softer wood, not too dense wood) will be enough to affect the sound and the guitar will still be playable, as a matter of fact, it may turn out to have a pretty good tone.
RCB
Find all posts by RCB
02-16-2007, 09:54 PM
Dee
Re: Insane guitar
That's not very exciting, though.
F*** it, let's see who can make the heaviest guitar.
LOL
Dee
02-16-2007, 10:00 PM
C.Thep
Posts: 3,050 - iTrader: (
Re: Insane guitar
I would suggest to just put a thin layer of stone on a wood body, with the pickups mounted directly on the wood. I honestly think that completely stone guitar would sound horrible.
C.Thep
Find all posts by C.Thep
29
02-16-2007, 10:03 PM
C.Thep
Re: Insane guitar
Dee
LOL
that would be the Ibanez Brass artist wieghing 76 pounds
C.Thep
30
02-18-2007, 10:41 AM
MF_Kitten
Posts: 219 - iTrader: (
Re: Insane guitar
dude, donīt tell the guy to only make a thin layer of stone on it, i wanna see see what itīll be like when itīs all stone! :P donīt discourage him! :P
anyways, i was thinking it would be cool to fill the hollow parts of the guitar with wood, like basswood and mahogany... just cut them to fit the hollow parts perfectly, so it sits tight when you shove it in, then you add glue, and then you glue the other half of the stone on... so instead of hollow cavities, you have wood cavities... and make shure the pieces of wood make very tight contact with all of the inside cavity walls...
also, for simplicity, you could just make the cavities square, so the fitting of the wood wonīt be so difficult :P
OR you could make a long hollow cavity under the length where the pickups should be, so that the pickup-cavities are in the wood... so the pickups are mounted onto the wood...
what do yaīll think? :P
MF_Kitten
Find all posts by MF_Kitten
Page 2 of 14
base plate
beautiful guitar
custom shop
electric guitar
fanned fret
fret guitar
guitar body
guitar mag
high pass filter
les paul
neck angle
neck pickup
sounding guitar
steve vai
strat body
truss rod
wiring diagram
what guitar ibanez guitar is shawn lane using in his video
how do i fix a synsonics guitar?
what age guitar
what to use to lubricate nut on guitar
how to swirl a guitar
Funny guitar article
Dino
40
05-11-2007
09:24 PM
Girl or Jem?
rickcard71
Off-topic / Miscellaneous
97
03-27-2006
01:07 PM
Guitar Player, Guitar World Back Issues (Satch & Vai)
jippy
01:40 AM
guitar man with nothing but bad attitude
Joshka
10:58 AM
Any classical guitar gurus out there? looking for appraisal
Willin
07:55 PM
06:58 AM
