Go Back   Jemsite > Guitars and Gear > Other 7-string Guitars
Old 02-19-2004, 04:54 PM
aviad27 aviad27 is offline
Posts: 17  -  iTrader: (0)
its feel not so tight
i start to play my 7 string rg guitar today and its great ....
i got some q if you be so kind to halp me :
the 7th string the low b is a bit lose from the others .....what should i do ?
replace it ?
difrent gauge ?
i play with the factory strings right now ..... i think its 09 - 42 and 46 (7)
i think
i know its a ****y set up and im going to replace it for 10 - 56
you think its going to fix it ?
thanks fot your time ....
aviad-israel
Old 02-19-2004, 04:56 PM
Rich Rich is online now
Posts: 18,372  -  iTrader: (18)
Standard low B for a 9 set is a .54.
Old 02-19-2004, 05:08 PM
lose string
thanks man ...... i dont think its what i got on my guitar but maybe you right ....
im still dont know what to do about the lose string
i red somwere around here i think that its bec of the scale (25 1\2 ) insted of 27.....
but my q is if i change the gauge set up on all stings the lose problem gone?
what gauge will be tighter .... thin ot more havey ?
thanks aviad
Old 02-19-2004, 05:20 PM
If you want more tension go to a 10-7 set, you'll get plenty of extra tension
Old 02-19-2004, 05:29 PM
bachle7 bachle7 is offline
Posts: 365  -  iTrader: (0)
Heavier gauge of string will be tighter. I had a 46 on my 7-string and it was REALLY loose, but when I put a 54 on the B, it was perfect with my set of 9s.
Old 02-19-2004, 05:39 PM
strings
thank you very much !
i order the dean markley korn 7 string signature packs 10 -60
so i think it will do the trick !
right?
thanks alot
aviad
Old 02-20-2004, 03:36 AM
Yes, you are correct. Let us know how they work out for you!
Bookmarks
dean markley, string signature
