Old 07-27-2003, 08:53 PM
nosferatu123  is offline
Posts: 52  -  iTrader: (0)
Just got my first 7 string.....(and i need help too)
And guess what, its a RG 2077 XL. Beautiful guitar. totally beautiful, reminds me of the K7. But i do have one problem though. Seeing as i have never used anything else but a fixed bridge in my entire life of guitar playing, could someone tell me how to get the bridge back parrarell. The stock tuning was one step lower. So i loosen the locking on the nuts and tuned to a (A,E,A,D,G,B,E,) which is the tuning i'm intending to have on the guitar. After tuning the guitar, the bridge moved out and i understand this is a normal thing, but how do i go about getting back parrarell? Thanks.
Old 07-27-2003, 09:02 PM
Jeff  is offline
Posts: 1,501  -  iTrader: (1)
Read the tech section on jemsite...there is more to this site than a forum you know...
Old 07-27-2003, 09:29 PM
Jim Soloway  is offline
Posts: 518  -  iTrader: (1)
I know absolutely nothing about trem bridges, so I can't help you, but congratulations on the 2077. I understand it's a terrific instrument.
Old 07-27-2003, 10:26 PM
thanks a lot JIM, you were the main reason why i got the XL neck. After reading your post about your 7421XL and listening to your Jazz playing, i knew the XL neck was what i needed. Thanks again!!!
Old 07-29-2003, 02:17 AM
The Dark Wolf  is offline
Posts: 688  -  iTrader: (1)
The long and the short of it, nosferatu, is that you have to tighten your trem springs (more tension to counteract the added string tension.) Read the tech pages for precise info.
Old 07-29-2003, 02:22 AM
Petie  is offline
Posts: 2,878  -  iTrader: (0)
Basically pop off the back plate, loosen the string pads at the nut, and keep tinkering with the screws in the spring cavity and retuning until it's where you want it.
Old 07-29-2003, 08:54 PM
ok, this is the strange part. I loosened the string pads and tighten the trem springs but the bridge isnt moving at all. Could i be doing anything else wrongly?
Old 07-29-2003, 09:29 PM
Rich  is offline
Posts: 19,355  -  iTrader: (21)
Forgettting to retune?
Old 07-29-2003, 11:34 PM
Ok, let me get this straight, after i tune the guitar, how many times do i have to turn the screws before i retune it again?
Old 07-30-2003, 12:26 AM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
The pitch will start rising as soon as you start screwing in the claw, then you'll have to tune down to get back to concert pitch.
Adjust the claw so you get the bridge about halfway to where you want it. Tuning down will get you just about there.
Old 08-03-2003, 03:55 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Three words: "Trial and Error." Keep making small adjustments and retuning until you get it right. Expect about an hour, maybe more, if this is your first time ever doing this.
-D
Old 08-03-2003, 10:16 PM
Ok, i finally got it done and now it sounds absolutely killer. Thanks a lot for all your feedback. I'll try posting some pics of the guitar soon...
beautiful guitar, fixed bridge, guitar playing, spring cavity, string tension, trem springs
