Other 7-string Guitars
KORN setup? KORN sound? still trying
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
Page 2 of 12
02-25-2004, 06:00 PM
Two hands31
Posts: 4,989 - iTrader: (
From the first clip it sounds kinda like my problem (which is probably a scale-length or
string guage
problem) but not as bad as mine
As for the distorted sample, you've definitely got the early (fuzz/disortion pedal) Korn sound from their first album.
Without a big half/full-stack
tube amp
(Diezel, Hughs & Kettner, Mesa/Boogie Dual/Triple Rectifier/Road King, even Marshall, take your pick Korn's used them at some point) I don't think you'll get it perfectly. Darren had a good point that it has a lot to do with the two guitarists combining. While it sounds like a big wall of distorted sound, they're very good at picking different tones that work well together.
But overall, I think your tones are just way too solid-state/distortion pedal sounding.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
02-25-2004, 06:05 PM
Chud
Posts: 926 - iTrader: (
i have the same problem...
The 7th string is constantly going in and out of tune when hitting it hard aswell.
Im thinking about getting a 27" neck which would probably help
Chud
Find all posts by Chud
02-25-2004, 10:09 PM
Joshka
Posts: 73 - iTrader: (
http://www.harmony-central.com/Software/Windows/apguitargset
there is a pretty cool software guitar tuner here:
http://www.harmony-central.com/Softw...targsetup.html
if you set your recording device as the wave input, you can use my mp3 to get a reading on the tuner.
try it. it works
Joshka
Find all posts by Joshka
02-26-2004, 01:00 AM
toshiro
Posts: 1,812 - iTrader: (
Personally, I feel that no matter how much you tweak, you'll never get a sound exactly like your favorite recording.
Why? Because the typical music cd can have 2-4 tracks of guitars on it.. Double(Triple-Quad-etc) tracked guitars can sound massive all on their own.
I used a .060 for a low Ab once, hated it... It was far too 'boomy'.. I prefer a .056 for B(and Bb) or a .058 for drop A(and Ab) on my RG7620.. I'm not going for korn's sound, though.. I do play gallop riffs on the low string, and I have no problems with tension..
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
02-26-2004, 05:16 AM
Ancestor
Posts: 297 - iTrader: (
As far as uneven pitch response, I'd say that you probably need to move up in string guage. I use a 60, and I'm tuned to B flat. Maybe a 65 would work. If you tune a string a couple of frets lower than whatever the standard pitch is for that guage, you can see that the shape of the vibration of the string changes. It gets slightly smaller, then larger. That affects the pitch stability. This is particularly true for the open notes.
The lower you tune, the more problems you'll have with intonation. Thicker strings will help, but what you really need is a longer scale length. If you don't have adequate scale, you'll have to compromise your intonation. If you think about it, you're tuning you're low string to the same note as the A string on a standard-tuned bass. Look at the difference in scale length between the two.
Chorus may help you to come closer to the tone that you want, but any professional CD that you listen to has lots of guitar tracks - at least two playing each part.
Don't give up. As you get used to playing in the lower tuning, your technique will adjust to what you're hearing. It gets better.
Ancestor
Visit Ancestor's homepage!
Find all posts by Ancestor
02-26-2004, 10:39 AM
darren wilson
Posts: 4,190 - iTrader: (
Try using heavier strings and make sure your intonation is bang-on. Get a good-quality accurate tuner and follow
Rich's intonation guide
. Also make sure your pickups aren't too close to the strings.
I'm not sure what's causing that "beating" sound on your low string. It sounds like some kind of phase problem, but i'm not an audio engineer, so i can't really be more specific than that.
Overall, i find your tones to be far too buzzy and solid-state sounding, likely a result of the particular distortion you're choosing to use and the amount of gain. My philosophy is to use the amp gain as much as possible, then add a
distortion pedal
in tiny amounts just to enhance and slightly colour what i'm not hearing in the amp model alone.
darren wilson
02-26-2004, 11:26 AM
Joshka
Thanks for all your input. I have actually just gone back to standard B tuning, with D'Addario XL 10-56 gauge, and its sounding great.
All of what your saying could be right, perhaps my pickups were too close to the strings?
I am not sure, maybe if you detune to A from B, you might have to adjust the pickups to be further away from the strings?
has anyone ever heard of that?
but as for my sound now, it sounds great.
i've also just put new D'
Addario strings
on my Rg270, which is now in dropped C - also sounding AWESOME.
That little cheap korean mande thing is AWESOME
CGCFAD rocks!
Joshka
02-26-2004, 11:54 AM
The Dark Wolf
Posts: 688 - iTrader: (
Filth...?
Well, at any rate, I love Korn
, and there's a FEW (read-FEW) more on this board who dig 'em, too, but I don't think you're going to get a whole lot of agreement on that statement, Joshka.
Glad you're happy with your setup, tho.
The Dark Wolf
Find all posts by The Dark Wolf
02-26-2004, 12:25 PM
darren wilson
Joshka
It wouldn't surprise me. When you lower the pitch, especially on guitars in that range, you lose a fair bit of tension, so pickups that are too close to the strings might "tug" on them a little more than normal, which could possibly give you an unstable sound and tuning difficulties.
The expanded string excursion on the lower-pitched strings also produces a lot more vibration in the pickup's magnetic field, so backing off the pickup a bit helps keep the signal from getting too hot and garbled.
darren wilson
02-26-2004, 12:28 PM
dex
Posts: 1,972 - iTrader: (
Just want to add that the 3rd try on the recto sound clip was almost spot on.
There's this warmness and smootheness in Korn that just projects and it's the exact oposite to Metallica's tone which is what you sound like in that Phat.riff thing.
Just start doing it at 160bpm like Jaymz and it's like you are playing on the StAnger album.
Also keep in mind that not only Head and Munky guitar sounds intertwines but also there's huge rhythm section and the bass acts as a very solid background that makes everything sound even huger (made up a word
Try the 3rd setting with your
neck humbucker
or try rolling the tone off a bit but if you ask me you are never going to get real close even if you have the exact same equipment because what you hear from your stereo has been mixed, produced, EQ'd and tweeked to sound great on an average stereo with 5" speekers.
ilia
dex
Find all posts by dex
02-26-2004, 08:35 PM
Joshka
Wordwolf, which statement?
Joshka
02-26-2004, 11:02 PM
Two hands31
dex
Try the 3rd setting with your neck humbucker or try rolling the tone off a bit but if you ask me you are never going to get real close even if you have the exact same equipment because what you hear from your stereo has been mixed, produced, EQ'd and tweeked to sound great on an average stereo with 5" speekers.
ilia
I'm not sure that's true about their new album, maybe it's just my laptop, but it sounds like things are clipping all over that album...great songs IMHO, just sounds like it's clipping a lot...
Two hands31
02-27-2004, 12:00 AM
Joshka
I like their sound frm the first 4 albums
Joshka
29
02-27-2004, 04:03 AM
dex
I've only listened to Untouchables a few times and that was a year ago and still have not heard the new album.
I'll probably get it at some point but after the last one I'm not in a hurry to get the most recent one.
ilia
dex
30
02-27-2004, 05:26 AM
toshiro
Not to hijack the thread, but this is my idea of a decent 7string tone:
http://www.soundclick.com/bands/2/toshiro77music.htm
Look for the clip titled 'Death-
Thrash Metal
Idea'..
(Warning, sorta big file for a clip, at 2meg)
B tuning, .056 low string, RG7620 using the
bridge pickup
(Evo7), J-Station -> Line in...
Definitely flat the EQ if you play this clip, though..
toshiro
Page 2 of 12
addario strings
amp modeler
amp settings
beautiful guitar
boogie road king
bridge pickup
bridge pup
bridge saddles
chorus pedal
clean tone
combo amp
darren wilson
dean markley
dean markley blue
dean markley blue steel
death metal
dimarzio blaze
dimarzio super distortion
distorted tone
distortion pedal
dual rectifier
dual recto
engl powerball
ernie ball
fender strat
fret buzz
guage strings
guitar shop
ibanez guitars
johnson millenium
les paul
les pauls
locking bridge
low strings
lower strings
mahogany body
maple neck
markley blue steel
mesa boogie
mesa recto
neck humbucker
neck position
palm mute
piezo system
power amp
ron thal
schecter revenger
scooped mids
squier strat
string guage
string tension
super distortion
thrash metal
tone zone
triple rectifier
triple recto
tube amp
tube amps
tube power amp
would active pickup sound bad without batteries ?
fret setup level how-to
how to setup a stratocaster
how to setup an edge 3 tremolo
what setup does korn use
03:54 AM
