Other 7-string Guitars
Mahogany: An Unstable Neck Wood for a 7?
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
07-03-2007, 02:29 AM
Codyyy
Posts: 68 - iTrader: (
I'm concerned about the stability of a mahogany neck on a 7 string. What do you think? Reliable or unreliable?
Deal is, I'm GASsing for a 7 string, and one that came to mind that plays really nicely is the Schecter c7 Hellraiser. However, the neck is all mahogany, and I know it's somewhat weak/porous. Will the added tension (especially since it's a 26.5" scale length) cause it to warp too easily? It's a $700 guitar, if you don't like it and have better options close in the price range, that'd be awesome.
Codyyy
Visit Codyyy's homepage!
Find all posts by Codyyy
07-03-2007, 03:08 AM
David McCarroll
Posts: 2,049 - iTrader: (
Re: Mahogany: An Unstable Neck Wood for a 7?
Mahogany should be fine if it is properly seasoned before being machined. The real issue with Mahogany is that it has a short grain, and a somewhat brittle nature, as opposed to Maple's long, stringy, slightly elastic nature, so you have to be reasonably careful with the guitar - always on a good stand, or in its case, and never, ever leave it lying on its back with weight on the headstock - you can supposedly break the headstock off an SG by dropping it back down less than six inches - because the top of the headstock is what takes the impact first, it breaks the neck just behind the nut.
So, no, Mahogany should not be an issue stability wise, but you DO have to be a little more careful with Mahogany necks - especially with an angled headstock.
David McCarroll
Find all posts by David McCarroll
07-03-2007, 08:26 AM
rbjammin
Posts: 81 - iTrader: (
I recently made a 7 string, 27" scale with a set mahogany neck and it has been no trouble. The only finish is
tung oil
. Although, the guitar has never left my house, and I'm not one to beat up a guitar (especially one that I made).
You can see pictures
here on the forum.
rbjammin
Find all posts by rbjammin
07-09-2007, 04:01 PM
kmanick
Posts: 134 - iTrader: (
My Carvin 7 has a mahogany (tung Oiled) neck.
No problems here, but Carvin does use 2 re-enforcement bars in their 7
strring necks for added stablilty. Probably not a bad idea.
kmanick
Find all posts by kmanick
07-09-2007, 04:06 PM
Devnor
Posts: 90 - iTrader: (
Doesnt the new 7 string Petrucci F-1 have a mahogany neck?
Devnor
Find all posts by Devnor
07-09-2007, 04:52 PM
jim777
Posts: 8,943 - iTrader: (
If I had my choice I'd only get mahogany necks going forward on everything. My Carvin has a two piece mahogany neck, and it's fantastic.
jim777
Find all posts by jim777
07-09-2007, 05:02 PM
540s
Posts: 455 - iTrader: (
Mahogany is a great wood for necks (& bodies for that matter) .. even the zen mahogany used on the schecters et al.
I would not have any hesitation.
540s
Find all posts by 540s
07-10-2007, 01:28 AM
TheOrangeChannel
Posts: 381 - iTrader: (
Devnor
Yes and it's painted. Raw mahogany has a short shelflife because the sweat with cause it to rapidly degrade, therefore you can't go rawdog on that stuff unless you want replace the neck...often.
TheOrangeChannel
Visit TheOrangeChannel's homepage!
Find all posts by TheOrangeChannel
07-10-2007, 03:58 AM
Dino
Posts: 1,721 - iTrader: (
David McCarroll
I'm going to guitar center in the morning to try that!
Dino
Find all posts by Dino
07-24-2007, 01:57 PM
Drew
Posts: 4,538 - iTrader: (
If you're at ALL uncomfortable, the Blackjack is essentially the same guitar, just with a
maple neck
and passives. Personally, I prefer the snappier tone of a maple neck and don't get on with EMG's for rhythm, so within a couple weeks of buying a Blackjack I'd put my Hellraiser up for sale.
That said, I've had no problems with mine when I owned it, knew a lot of fellow hellraiser owners who also had no problems, and a bunch of the sevenstring.org crew swears by mahogany necks for Carvins.
Drew
Visit Drew's homepage!
Find all posts by Drew
07-24-2007, 11:11 PM
eelblack2
Posts: 865 - iTrader: (
No issue with mahogany on my COW7 necks or my
Les Pauls
for that matter.
eelblack2
Find all posts by eelblack2
david mccarroll
les paul
les pauls
maple neck
tung oil
dimarzio or seymour duncan? mahogany
parker are they neck thru
how can i tell thin or standard neck prs
why is through neck construction expensive to produce?
basswood is cheap wood
Will a Ibanez squared heel neck fit a Jackson body?
ZOMB13
Tech: Setup, Repairs and Mods
11:25 PM
Painted neck? Sanded neck?
Drache713
12:45 AM
A possible fix for that unstable neck.
mlr_pa
02:27 PM
Jem 7DBK neck confusion...
Spagbol
05:48 AM
JEM neck and JPM neck - Comparason
Matt55655
06:51 PM
06:27 AM
