Re: Pickups act like a microphone.
Here is what the manufacture just wrote me.
"It is normal to be able to hear your voice through the pickup when the strings vibrate in response to your voice. If you remove the strings and you can still hear your voice, that’s not normal. The pickup might be mounted too loosely. You can try stuffing some foam rubber under the pickup to tighten up the mounting. There might also be excess pickup cable vibrating inside the guitar, which can cause the same effect. If the pickup itself is microphonic, we might be able to improve it by re-potting the pickup. However, if you are not getting feedback, you might consider this to be a feature rather than a problem."
