Old 06-13-2003, 02:39 PM
213  is offline
Posts: 4  -  iTrader: (0)
question about tremolos
Hi. I was wondering if it's possible to replace the Lo-TRS 7 piece o'**** in my RG7420 with a Lo-Pro Edge 7.
(I already have a better guitar, I just want to use this one as a backup, but the trem sucks). Thanks!
Old 06-16-2003, 08:19 AM
213  is offline
Anyone?
If you don't know the answer, do you know someplace I can find out? The Dutch Ibanez distributor won't answer.
Old 06-16-2003, 09:45 AM
sam669  is offline
Posts: 835  -  iTrader: (0)
you can find a lo-pro with everything else on etray.
then see a luthier to route out the body
Old 06-16-2003, 05:01 PM
GhesQi J  is offline
Posts: 221  -  iTrader: (0)
Normally it's possible to order a Lo-pro edge 7 through your local Ibanez Dealer.
I did it that way. Prepare for long waiting times, mine took me almost 7 months to arrive !
Cheers,
joten
Old 06-16-2003, 05:29 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Or you could always order from somebody that has them in stock but IMO a 7420 isn't worth the expense.
Old 06-16-2003, 06:11 PM
caprile  is offline
Posts: 1,619  -  iTrader: (6)
since you want it as a backup, just block the trem!
Old 06-16-2003, 06:33 PM
EKG  is offline
Posts: 2,280  -  iTrader: (0)
You need to route out the existing TRS cavity to accomodate the LoPro. LoPro Trems and other Ibanez trems can be found at IBANEZ RULES (top banner). Is it worth it? Entirely up to the individual. For me? No.
Old 06-17-2003, 12:39 AM
guitarkatana  is offline
Posts: 635  -  iTrader: (0)
I gotta agree with Rich, 213. Unless you absolutely cannot perform your music without a floyd trem, just do what Caprile suggested. If you can't perform without a floyd, I recommend you aim at buying a better guitar for backup, or get used to the one you have. The price to buy a Lo-pro Edge and get your guitar body routed doesn't sound like a great deal, just for a 7420. At least not to me. Now, if you're able to route the body and repair the finish yourself, go for it.
Old 06-17-2003, 08:31 AM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
well if you don't mind a little routing
and an ugly spot on your guitar unless you refinish it
personally i think it could be well worth it if you want to try doing it yourself
it'll increase the resale value too
try a search on jemsite and projectguitar
i'm sure i've seen the measurements to do this somewhere before
good luck
floyd trem, guitar body, ibanez dealer, ibanez trem, lopro trem, pro edge
