Old 09-11-2006, 04:08 PM
NeglectedField  is offline
Posts: 945  -  iTrader: (0)
Replacing with Dimarzio 4-conductor wired
First off I assume the wiring diagram given on the US site is correct. Mine's a RG7321 with the same 5-way switching as the normal 5-way stuff and I'm changing the bridge pickup. What I want to know is do Dimarzio pickups' wires have the same colours as the stock Ibanez ones and if not, what colours correspond to which colour on the stock Ibanez ones?
I'll only have two days to change the pickup assuming it finally arrives on Wednesday so I take it it's just a matter of soldering in the wires the way the original pickups were soldered in?
Old 09-11-2006, 04:40 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: Replacing with Dimarzio 4-conductor wired
from memory - if im wrong someone will correct me ! and this is assuming that the pups on your 7 string have the same wire colours as the Vx pups.
Black and white - wired together to where the white wire was on the stock pup.
Red - goes where the red wire from the stock pup went
green and braid both to ground.. (the back of the pots)
thats all I did in the past with dimarzio's
J.
Old 09-12-2006, 10:46 AM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
I just installed a pair of Blazes, and for straight-up installation (no tapping, phasing, etc.), I followed the instructions on the website and it was like what the guy explained above, except you wire the black and white together and tape it off (don't connect it to anything).
Old 09-12-2006, 08:35 PM
The whole black/white cable thing confuses me, I should hope it becomes clearer at the time!
bridge pickup, dimarzio pickup, dimarzio pickups, wiring diagram
Do you prefer 'brand name' DiMarzios or DiMarzio/ IBZ TheJazzTerminator Polls 5 08-18-2006 06:16 PM
FS: Dimarzio Pickups and Cliplocks gpenguins Classified Ads: Guitars and Gear 12 06-02-2006 10:14 AM
...in praise of DiMarzio ibanez otaku Gear and Equipment 20 02-14-2005 08:07 PM
Replacing an Ibanez pup with a dimarzio FRED warjockey Pickups & wiring 0 05-23-2003 04:22 PM
