Old 06-30-2005, 12:30 PM
cakewalkr7  is offline
Posts: 35  -  iTrader: (0)
Unhappy
rg1527 trem problem
My high e string keeps breaking right over top of the little roller bearing type part in the tremolo. It definitely has a groove in it and I'm wondering if there's a way to turn it. It looks like it just sits in there and should be able to be turned, but I can't get a grip on it and it doesn't seem to want to move. Aside from getting a very tiny file to file it smooth, what can I do? I just got this back in February, so I'm surprised I already wore a groove in it.
Old 06-30-2005, 12:58 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Re: rg1527 trem problem
Id be surprised if you have an actual groove. that guitar should have the edge pro in it so it doesnt have a roller bearing. Just the insert chip. I havent gotten to deal with these yet so you may want to ask Rich on this one
Old 06-30-2005, 01:08 PM
Rich  is offline
Posts: 19,348  -  iTrader: (21)
Swap it with another saddle.
Old 06-30-2005, 01:48 PM
But how do I get it out? I had the string off and I couldn't really get a grip on it to pull it or anything? Thanks Rich.
Old 06-30-2005, 02:12 PM
Rich  is offline
Take the lockdown/intonation screw off and pull the saddle.
Old 06-30-2005, 02:51 PM
Oh, okay. I was cornfused. I didn't realize you mean the whole saddle. I'll that a try. So, there's no way to rotate these things? Thanks.
Old 06-30-2005, 03:07 PM
JTM45  is offline
Posts: 1,008  -  iTrader: (1)
No. A few people have posted here thinking that the Edge-Pro saddles are a 'roller-saddle' type thing but they're not at all.
Old 06-30-2005, 04:49 PM
So, after a few saddle switches, do I have to try to file them or replace them or what? At this rate, I will have gone through them all in about 2 years.
Old 06-30-2005, 11:20 PM
Angry
man, now my b string just broke. I checked it and sure enough it has a groove in it too. these saddles are junk. I've never had a tremolo wear this quickly before.
Old 06-30-2005, 11:32 PM
Well, I figured that since I had to replace my b string, I may as well check out the other saddles. They're all worn (with plenty of grooves). This is ridiculous. I'll try to find my paperwork, but does anyone know off hand if this is covered under warranty? I definitely use my whammy a good amount, but it's not like it takes over my playing... which is what these saddles makes it look like. Rich, does this sound like a bad trem to you or have you heard of this problem before with this model? Thanks.
Old 07-01-2005, 03:01 AM
ZJH  is offline
Posts: 148  -  iTrader: (0)
I don't think warranties cover damage due to aging and regular usage. At least, almost all warranties say something like that.
Old 07-01-2005, 09:20 AM
First off whens the last time you changed strings? I honestly think your just breaking them from usage, in years ive never seen that many sharp saddles and i honestly dont think ill beleive you till you post pictures of the saddles
Old 07-01-2005, 12:28 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
This was always a problem with Edge and Lo-Pro saddles, too - simply grab a small file and lightly touch it up to remove the burrs.
Frankly, I'd be shocked if they're wearing faster than an Edge or Lo Pro, as I was under the impression that these were stainless steel inserts...
Old 07-01-2005, 01:11 PM
TheOrangeChannel  is offline
Posts: 381  -  iTrader: (1)
I get this all the time about the JP MusicMan Trems also...pretty much any guitar with the piezo option has the inserts that are mistaken for rollers...I'm guessing Ibanez used this design due to offering a piezo on the 6 strings and they use the same saddles soooo....
Old 07-01-2005, 01:22 PM
JTM45  is offline
I don't think the saddles are the same on the Double-Edge Pro piezo bridges.
I've got a Double-Edge Lo-Pro 7 Piezo equipped trem and the saddles are completely different to the normal Lo-Pro 7.
double edge pro, piezo bridge
RG570 Trem problem shader Tech: Setup, Repairs and Mods 10 04-22-2005 08:50 PM
tremolo problem.... :( rx JEM and Universe Guitars 14 04-01-2005 07:45 AM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit Dean Southcombe Tech: Setup, Repairs and Mods 5 06-11-2001 10:09 PM
UV777PBK trem problem - Very stiff wyzenhymer JEM and Universe Guitars 12 04-23-2001 06:21 PM
