Old 07-30-2009, 11:52 AM
caughtinamosh  is offline
Posts: 22  -  iTrader: (0)
RG7 baritone (mockups inside!)
Hey guys,
I thought that you'd like to see the mockups/specs of my upcoming RG7 baritone. The neck is being built by ETGuitars. The body *may* be a Sims, or another ET product. Time will tell. Kudos to Randy over on sevenstring.org for making these.
The way things are, I'm going to opt for the purple one. The specs will be as follows -
28" scale
25 frets (there are 27 on the mockups)
ebony freboard
mahogany back
quilted maple top
Bare Knuckle Miracle Man bridge humbucker
Bare Knukle Cold Sweat neck humbucker
volume knob
Hipshot bridge
/post
ciam
Old 07-30-2009, 02:03 PM
nato101010  is offline
Posts: 1,002  -  iTrader: (0)
Re: RG7 baritone (mockups inside!)
That is pretty awesome.
It seems custom guitars and the way to go. People like things about a production model, but little quirks put them off, and they do what you are doing. Any idea how much it'll cost?
Old 07-30-2009, 02:25 PM
Agent540  is online
Posts: 1,073  -  iTrader: (0)
yumyum !nice project !
Old 07-30-2009, 02:37 PM
6fingers  is offline
Posts: 3,167  -  iTrader: (0)
Reviews: 63
no FR !!!
Old 07-30-2009, 02:42 PM
Yeah, I've never really been hapy with the prduction 7-strigs on offer, mostly down to the lack of baritone scales (in the sense of being "long scale"). As for the cost... If you want, I can PM you the price of the neck and body. The Bare Knuckle pickups cost me about £100 each.
Cheers, dude!
Originally Posted by 6fingers View Post
no FR !!!
No chance! I heart hardtails.
Old 07-30-2009, 06:21 PM
g.milko  is offline
Posts: 281  -  iTrader: (0)
Originally Posted by caughtinamosh View Post
Hey guys,
28" scale
ebony freboard
mahogany back
quilted maple top
volume knob
Hipshot bridge
/post
ciam
prety hot but...
ok it's 28" how low can that go...?
Old 07-30-2009, 07:07 PM
Originally Posted by g.milko View Post
prety hot but...
I have no idea how low it could go and still retain clarity, but I only intend to tune it with a low B.
The reason? Longer scales promote a clearer tone, which I find standard scales to lack. You can definitely achieve a decent low B sound using standard scales, but I have an especially strong hatred towards even slightly muddy tones, so extended scale seems to be the way to go.
Old 07-31-2009, 10:34 AM
g.milko  is offline
you know?....more inches = less bend, stretch, 4finger liniar...
i believe try it with low guage....just for test it....meshuggah are playing with 27" and your rg7 it's 28"!!!!
you must play like a bass player i mean maybe you can go lower than F....that's E! like normal bass......
Ibanez create a new bass: SR7 it's a seven string bass (for tech death metal or soloist job also jazz fusion)
spec:
5pcs Maple/Bubinga neck
Mahogany body
Medium frets Gibraltar Custom Bass VII bridge (11mm string spacing)
Quik Change Bass VII tailpiece
Duncan® Ibanez (J) neck pu
Duncan® Ibanez (Jx2) bridge pu
Vari-Mid III 3-band eq
Factory Tuning : 1E, 2B, 3G, 4D, 5A, 6E, 7B
String Gauge :
.025/ .035/ .045/ .055/ .075/ .095/ .120
Hardware color : Cosmo Black
Scale : 770mm/30.3“
you can see that in japaneze site...so you are between rg2228 and SR7
and by the way it's bolt on right? or not?
Old 07-31-2009, 02:30 PM
spec:
Mahogany body
String Gauge :
Scale : 770mm/30.3“
I've heard that longer scales actually offer increased "bendability" due to the fact that there is more string between nut and saddles. If I still find it too hard to bend, I will simply decrease the size of my treble strings.
Meshuggah's 8-strings actually have a scale length 30.5". They tune with a low F. I might give extra low tunings a shot, although I don't think that I'd keep it in that, simply because it can become very muddy when playing power chords etc.
That bass-hybrid sounds interesting. I'll definitely give it a look.
Old 07-31-2009, 05:36 PM
g.milko  is offline
yeah i'm sorry.....i was thinking about rg2228 scale length (27")....sr yeap meshuggah using punch of baritone 8s....
SS:: Ok Marten, we're all gear nuts here - Can you give us a quick rundown on your custom 7 & 8 string Ibanez guitars?
MH: Oh man, lets see. I've got an old black 'n green Ibanez Universe (got it 92/93) that I don't use anymore. It hangs in the studio more like a curiosity. Great guitar though. I got one standard scale black Ibanez Custom 7-string bolt-on neck called "MH" because its got my initials as a fretboard inlay. Another black Ibanez Custom but with Extended scale bolt-on(27 inch if I'm not mistaken) and one Ibanez Custom 27" scale neck-through. Its grey and the lid is Flame-maple I think. I have one Black/worn Nevborn Custom which is standard scale, neck-through. I also got a 7-string acoustic Ibanez. That's it for the 7's.
Now for the 8's. I've got 2 Black Ibanez custom 8's 30" Neck-through. One Ibanez Custom 8 with piezo, black bolt-on neck 30 ". And finally I have a Nevborn custom 8. Black (big surprise) 29" neck-through. Now I'm unsure of the respective wood selections but all guitars except for the Universe are fitted with Lundgren pick-ups.
but hold....i'm usin a uv777 in drop G (and tune A) with gauge 070 + 065 and it's just 25.5"
so you can go very loooow
oh and by the way...more inch = less bend cause....
the tension in 24.75" guitars (eclipse, les paul, blabla) it's short = more bend
Old 08-01-2009, 08:19 AM
Quotations from my home-forum...
I realise that, if you keep the string guage and pitch constant, there will be more tension, and this will probably result in less bendability, but, due to the increased length of string between nut and saddles, there is more that you *can* bend. It's hard to describe, but it's not as simple as "longer scale = less bend."
Old 08-01-2009, 10:28 AM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
I like it. Its simple, yet beautiful. Who needs a floyd rose?
Old 08-01-2009, 10:54 AM
NickCormier  is offline
Posts: 788  -  iTrader: (8)
I hope you dont plan on playin much chords (triads or more) on a baritone like that! doesnt ring out as nicely as 25.5, which is my reason for staying with 25.5 for my ET RG7.
Old 08-02-2009, 11:52 AM
Thanks, dude! \m/
I don't. For that, I have my ES335, which has an even shorter scale (24.75"). I love that guitar. Its tone is so sweet and mellow.
Old 08-03-2009, 11:12 AM
g.milko  is offline
thats et job...! so, now i thing i have to take a guitar from there..
bare knuckle, baritone, etguitars, rg7, sims
New mockups! Infinity 7's for your eyeballs! Variant Other 7-string Guitars 24 08-05-2007 05:22 PM
Non-RG ibanez 8 string mockups, pics inside! MF_Kitten Other 7-string Guitars 14 05-04-2007 10:21 AM
Photoshop Mockups. nocluejimbo Other 7-string Guitars 4 11-22-2004 05:18 PM
Custom 7 mockups Farbaute Other 7-string Guitars 19 11-13-2004 05:02 PM
what is a baritone guitar - Baritone guitat ? armandocordero Other 6-string Guitars (non-Ibanez brand) 1 01-16-2001 01:43 PM
