Old 06-23-2006, 12:29 PM
giannifive  is offline
Posts: 484  -  iTrader: (8)
RG7 in RG550LC Case?
Does anyone know if an RG7 will fit in an RG550LC case (the one shown below)? Ibanez bills it as a lefty case since it's not form fitting around the body (it's apparently just one big open compartment below the neck joint). If it's long enough to fit an RG7 it certainly would be convenient, because it's cheaper than a UV1000C.
neck joint
Quick case quesiton concerning 1077xl / rant. MidusGT Other 7-string Guitars 5 11-26-2004 07:56 PM
JEM 10th Case Mystery Solved! - Would you believe?? Rich Archived Topics and Common Questions - GO HERE FIRST 55 06-24-2003 08:05 PM
Jem 10 Case Question jem10 JEM and Universe Guitars 6 04-26-2003 10:08 AM
JEM 10th Case Mystery Solved! - Would you believe?? Rich JEM and Universe Guitars 55 12-28-2001 03:54 PM
