Old 02-14-2007, 10:33 PM
Travis  is offline
Posts: 30  -  iTrader: (0)
RG7620/7420 questions
I just picked up a very customized RG 7 sting. A buddy of mine filled in the neck pickup route, switch and volume knob and repainted it an awesome pink with purple holoflake. The bridge pickup is an Evo7.
Here's a couple of pics he took before sending it to me.
Here's the thing, the bridge is stamped LO-TRS but the neck is stamped 7620. Also, the neck has the bubinga stripe. Did some 7620s come like that? I noticed on the specs page the 7620 was listed as a 3 piece maple neck while the 7420 was listed as maple with the bubinga stripe.
Is the LO-TRS interchangeable with any other (better) 7 string trem? I'm trying to figure out if this was originally a 7420 with a neck upgrade or a 7620 with a bridge downgrade. Any thoughts?
Thanks so much.
Old 02-14-2007, 10:46 PM
ibanezdiehard  is offline
Posts: 764  -  iTrader: (1)
Re: RG7620/7420 questions
you have an RG7420, some of the early ones had 7620 necks on them
Old 02-14-2007, 11:04 PM
Travis  is offline
Thanks a bunch.
So, is there another trem that can be dropped in place of the LO-TRS-7 without any modification? Or, do I need to make do with the current bridge?
Old 02-14-2007, 11:08 PM
JackButlerGOT  is offline
Posts: 351  -  iTrader: (0)
I have a 7420 like that (bubinga stripe) and I have one with a one piece maple neck and scarf joint for the headstock.. both with lo-trs and japanese "F" serial numbers in the Magenta Crush color.
Old 02-14-2007, 11:38 PM
jim777  is offline
I'm pretty sure you can drop an OFR in there without modification. Since the trem and pickups were the only difference between the 7620 and 7420, most of the necks are marked 7620.
Old 02-15-2007, 12:19 AM
i might be wrong, but the LO trs 7 is a japanese trem.
so maybe a LO PRO will fit in it's place?
Old 02-15-2007, 11:04 AM
jim777  is offline
The Edge trems and TRS trems don't replace each other without routing. The TRS and OFR trems generally do allow for a quick swap, though.
Old 02-15-2007, 09:25 PM
7stringofablick  is offline
Posts: 73  -  iTrader: (0)
i'd like to know if they do (without mod)...becuase i'd love to switch out my Lo TRS for an org. floyd!
Old 02-16-2007, 05:52 AM
Aris_T  is offline
Posts: 597  -  iTrader: (0)
You will have to mod. I had to when I replaced the TRS of my 470 with an edge.
Old 02-16-2007, 05:55 AM
Aris_T  is offline
Awesome looking! I love one-humbucker 7 strings (ala F.Thordendahl/Dino)!
Old 02-16-2007, 08:00 AM
ok, i thought that the only reason the korean LO TRS wouldn't swap with an EDGE or LO PRO was because the string spacing was slightly different,
so i assumed cause the LO TRS on the RG7420 is japanese it would be a direct swap.
but if you had to mod with a 470 then it's the exact same senario except 1 extra string.
Old 02-16-2007, 09:35 AM
Aris_T  is offline
Yep! . It's not hard though! Good luck and enjoy your new trem !
Old 02-16-2007, 09:56 AM
velocity  is offline
Posts: 494  -  iTrader: (14)
awesome guitar!! if you ever get tired of her, let me know!!
Old 02-17-2007, 06:08 PM
Travis  is offline
So, has anyone actually done an OFR-7 swap for the LO-TRS-7?
Also, what kind of mods were needed to swap to the Edge-7 bridge?
Old 02-17-2007, 07:48 PM
zeamc  is offline
Posts: 70  -  iTrader: (0)
yeah, i'm up for her too. hahah
bridge pickup, edge trem, edge trems, maple neck, neck pickup, scarf joint, seymour duncan, trs trems
jem 7 wiring diagram questions Koss Pickups & wiring 0 09-08-2005 01:21 AM
Interview with Andy Timmons - Questions? toneslave Players, Bands, People, Music & Tours 1 12-18-2003 11:03 PM
A bunch of questions regarding an RG2020X Wadstein Other Ibanez Guitars (including Premiums) 0 12-17-2003 07:31 PM
Some questions regarding/Wood/Bridges/finishes etc etc Swirly Tech: Setup, Repairs and Mods 16 12-16-2003 03:32 AM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman JS (Satriani Model) Ibanez Guitars 6 09-08-2001 03:10 PM
