I've got a
Schecter Revenger-7 (similar guitar, just much much cheaper: flat top, cheap pickups, hardtail,
dot inlays, simple finish, etc.) and I can say you can't go wrong with Schecter. The only things you should be a little worried about are the bridge (as this is not a hardtail) and whether or not you'd be comfortable playing that guitar. The Avenger/Revenger shape is very awkward, the upper strap pin is on the back of the horn on mine and if you play sitting down you get poked in the ribs, and also it could really use an arm contour. It's also kinda neck heavy, and the neck takes some getting used to (it's not a thin, Ibanez-type neck).
