Go Back   Jemsite > Guitars and Gear > Other 7-string Guitars
Old 01-10-2007, 09:17 PM
MF_Kitten MF_Kitten is offline
Posts: 216  -  iTrader: (0)
Schecter necks VS Ibanez...
i´m thinking about getting a schecter 7 string, but i´m trepadacious about the necks, because people have been telling me how awfully huge and baseball-bat-ish they are, but how would you all compare it to say, a les paul? (i hate the necks on les pauls...)
also, does anyone have the neck dimensions? like width and thickness at first and last frets? anyone owning a schecter 7 string that are kind enough to measure for me? :P
i´m always insecure about purchases... have been since i bought an Edge III equipped RG, and then discovered hate tremolos... :P
Old 01-10-2007, 09:25 PM
elcid's Avatar
elcid elcid is offline
Posts: 7,337  -  iTrader: (10)
Re: Schecter necks VS Ibanez...
Which Les Paul necks do you hate? The 60s Slip Taper, rounded 59, 50's rounded, Classic 50's, Supreme rounded, or Early 50's rounded?
Old 01-10-2007, 09:28 PM
jaxadam's Avatar
jaxadam jaxadam is offline
Posts: 2,299  -  iTrader: (8)
Schecter 7 necks are pretty thick. I don't know the exact dimesions, but they are probably thicker than you average.
Thickness doesn't necessarily bother me, but this may be an issue to you, so your best bet is to play one before you decide.
Old 01-10-2007, 09:36 PM
i´ve played an epiphone Les Paul Custom, and a Gibson Les Paul Studio... both were outside my taste...the latter is ´59 rounded profile, the epiphone one i don´t know, but the Gibson version, the Les paul custom
(they both have the name les paul custom, so i assume the epiphone mimicks the gibson version) has a 1960s slim taper...
i´m really used to my wizard necks, they´re heaven to play... although, i´m afraid it might be my doom, now that i´m almost unable to get used to other necks hehe :P
Old 01-10-2007, 09:39 PM
elcid's Avatar
The Les Paul Custom has the '59 rounded, much fatter than the 60s slim taper, its the same neck as the studio
jaxadam's Avatar
I have two friends that bring Scheck 7's over here on the regular, and they are a totally different beast than a wizard neck, much different than my J-C 7 string.
My main guitar was a PRS custom 22 with a wide-fat neck. It actually took me a while to get used to a thineer neck.
Old 01-10-2007, 09:47 PM
so, anyone care to guesstimate difference in thickness? like in numbers?
and do you think the wizard-accustomisation will go away with usage of a schecter, or will i suffer from baseball-bat-sickness?
i wish other guitar companies could as much info on their sites as ibanez...
i also wish all guitar companies should start having more info about their stock pickups... especially ibanez... i wanna know specs, dammit! :P
Old 01-10-2007, 09:51 PM
jaxadam's Avatar
All I can tell you is this...
I can guarantee that at first, you will definitely notice a difference in the thickness of the neck. It will feel thicker.
I can also guarantee this. If you play it for a while, you will definitley get used to it with no problem; it will feel normal, and that will make all of the other necks you play feel so much slimmer.
It's a thicker neck, but that is not bad in my opinion. As to millimeters in difference, I have no clue.
Old 01-10-2007, 10:00 PM
well, it DOES sound promising, and i´m probably just afraid of something different, being an ibanezzer... i will see if i can´t afford a schecter 7 string, hopefully an extended scale one, as well as pickups
(please GOD helpe me out on this, in my ´´pickup choise for drop G tuning´´ thread! :P)...
if not, i´m gunna resort to ibanez... i think :P
i´ll just play some fat necked stuff in a guitar store and see if i can´t get used to it...
it´s not like i´ll be shredding anyways, the technicality in the music i play is about as advanced as Deftones... so yeah...
Old 01-10-2007, 10:36 PM
jaxadam's Avatar
Well then you will be fine.
Get a Scheck, it sounds like your speed right now, and if worse comes to worse, drop some pickups in it. It's like a hundred and something dollar job (depending on what you get).
It will give you a load of experience.
If not, get a 1527 and throw some EMGs in it.
I have friends with 7 string Schecks and they are totally happy with them.
Old 01-10-2007, 10:54 PM
i´m already working on the pickups (in my ´´pickup choise for drop G tuning´´thread :P)... i was originally planning on an RG 7321, but the ONLY reason i favoured it, is that it´s got a Wizard neck... everything else is much more attractive with schecters... so i thought hey, why limit yourself, if you can work around it, and get used to it instead... i mean hell, many people own and love them, so it can´t be too bad! :P
also, about the pickups, i asked dimarzio tech support (they must be really sick of me by now) about which pickups would be the LEAST muddy for Drop G tuning, and they said that the D activator neck would be the least muddy... but it doesen´t look like my kind of pickup, i mean it has like no lows, and very little mids, from looking at the tone chart... i´m thinking D-sonic or Blazes now... (or blaze custom)
Old 01-10-2007, 11:00 PM
Mind's Mirrors Mind's Mirrors is offline
Posts: 32  -  iTrader: (0)
I played a 7321 and that neck is pure sex. I went from that directly to a Schecter 7 and the neck was noticeable thicker but I still had no problems riffing around on it.
I am 6'2'' so my hands arent exactly small though.
  #13
Old 01-10-2007, 11:07 PM
height and fingers aren´t always related hehe... i have spider-y piano-fingers, long and thin, and i started off my musical ´´career´´ as a bassist, my first bass being an Ibanez SR 305 DX 5-string... so my first instrument ever had a fairly wide neck :P i then started playing guitar, and quit the bass...
so now i´m all guitar... still have the bass though, and still use it, great instrument it is...
also, i started with acoustic, and got an electric way later, and i played all sorts of songs on it, songs made for an electric... so i´ve played thick necks before...
the wizard neck has just spoiled me :P
  #14
Old 01-10-2007, 11:35 PM
new problem though: which of the schecter 7´s have painted necks, and which of them don´t? :P i prefer unpainted necks :/
  #15
Old 01-10-2007, 11:49 PM
jim777's Avatar
jim777 jim777 is offline
Posts: 7,078  -  iTrader: (23)
The Carvins are right in between the Ibanez and the Schecter, if that's a help.
