Old 06-07-2003, 10:27 PM
juiceofvenus  is offline
Posts: 52  -  iTrader: (0)
Seymour Duncan 7 string PU production halted?
I noticed that Duncan, no longer has the 7 string models on their site, so do Jackson, Schecter and ESP with the 7 string guitars. Only Ibanez still makes 7's............
Old 06-08-2003, 12:04 AM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
I don't recall Duncan ever really having a dedicated 7-string section. If you look under their regular Humbucker product listing page, it still says which models are also available in 7-string versions. Duncan 7-string pickups have always been a semi-custom-order product anyway.
Old 06-08-2003, 04:53 AM
I know that, but they're in the humbucker section:
check it out
http://www.seymourduncan.com/website...mbuckers.shtml
Old 06-08-2003, 04:26 PM
Did you actually go and read the model description page? The '59, JB, Distortion, Custom, Jazz and Invader models are all still listed as being available in 7-string versions.
Their 7-string pickups were never listed as distinct product model numbers. Nothing has changed.
Old 06-09-2003, 12:04 AM
btweensunandmoon  is offline
Posts: 221  -  iTrader: (0)
SD will still custom make them even if they cease to be a standard production models.
Old 06-09-2003, 02:23 AM
Jim Soloway  is offline
Posts: 518  -  iTrader: (1)
Dimarzio, Rio Grande, and Kent Anderson all make 7 string pickups and on their site, Duncan still lists the 59, the JB, the Duncan Distortion, the Duncan Custom, the Jazz, and the Invader as being available in 7 string versions as well as the Benedetto S7 and B7 which they make under license.
Old 06-09-2003, 09:34 PM
trajectory fish  is offline
Posts: 394  -  iTrader: (0)
I've been looking at the duncan website for quite a while, browsing for 7 string models, and I haven't seen any changes there :P
I sincerely hope they're still available, because I've been trying to get a Jazz 7 for quite a while now
Old 06-26-2003, 11:00 PM
jim777  is offline
Get a Benedetto if you want a real jazz pickup.
http://www.benedettopickups.com/products.htm
Duncan actually manufactures them; may help explain a lack of availability if that's the problem you're facing.
jim
Old 06-27-2003, 12:15 AM
jim
I've had a couple, and they were nice. But they're also $150 each with no discounting and need a whole lot of routing to install.
Old 06-27-2003, 10:32 PM
jim777  is offline
They may be 150, but you only need one, right? I was just thinking about getting one for my 175, but I've never heard anything about having to route a guitar to get one in. Is that specific to the 7's? I was thinking about getting a B-6 for the neck slot, but I certainly won't route the top to fit it in.
jim
Old 06-28-2003, 02:43 AM
jim
WIth a 175 you should have no problem. I put a B6 in an archtop about 10 years ago. I was no problem and sounded great.
Old 06-28-2003, 11:35 AM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
Jackson still has 7-strings as a custom shop option.
Old 06-28-2003, 06:59 PM
jim
I asked someone about that one, but I was told that the Benedetto was for hollow body guitars. I'm getting this for a solid body RG7.
Old 06-28-2003, 08:09 PM
jim
If you're looking for a nice warm jazz tone from the neck pickup, I've been using a Dimarzio PAF and I've been really pleased with it, happy enough to have put it on 3 guitars in all.
Old 07-01-2003, 11:08 PM
Well, I just got the SD jazz today, and put it in my guitar... I'm pretty sure I botched the wiring, but my first impression of the sound is that its too bright for my taste. It might be because I also have new strings on as well. I think I'll look into the PAF.
BTW, I could realy use some help with this. More at http://www.jemsite.com/phpbb/viewtopic.php?t=23390
Thanks!
-Bennett
custom shop, dimarzio paf, duncan distortion, hollow body, neck pickup, production model, string guitars, string pickup, string pickups, string section
