Old 03-28-2004, 06:20 PM
nabeelm  is offline
Posts: 48  -  iTrader: (0)
some RG1527 questions
what is a volute?does the rg1527 have one and is it good or bad for a neck to have one.I also wanted to ask if the neck on the rg1527 be flatter than the neck of the ESP LTD 7 string guitars and whats better the V pickups on the rg 1527 or the EMG hz's found onthe ltd 7 strings.thank you
Old 03-29-2004, 07:39 AM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
The volute is an extra bump of wood behind the nut to reinforce the joint there. It's not a bad thing, as it makes it stronger (unless you find it gets in the way of your thumb while playing, I've never had a problem myself).
Old 04-03-2004, 11:58 PM
Praetorian  is offline
Posts: 422  -  iTrader: (0)
yeah, that's a volute. Umm, about the pickups, I guess it depends what you're playing it through. I just tried out a 1527 today through a Peavey XXX and the thing sounded beyond amazing. Then again, if I bought one and played it through my little Fender Princton Chorus, it wouldn't sound nearly as good. The EMG-Hz pickups don't sound nearly as good as the active EMG's, but I wouldn't bother changing the V-7 and V-8 for EMGs because they already sound good. It's mostly personal preference...but wait, you can't try them huh? Well, if I were you, I'd just leave the V series pickups in. Either that or go for the active EMG's if that's your thing, or (this is what I'd do if I didn't already like the V's) put in some Dimarzio Blazes or Evolution 7's. It's all a thing about opinion.
Old 04-04-2004, 12:29 AM
bachle7  is offline
Posts: 306  -  iTrader: (0)
The V7-7 and V7-8 on my RG1527 sound really good through my Fender Princeton Chorus. However, I'll likely swap out the bridge for an Evo7 sometime as I'm looking for a little sharper bite. I think the neck pup sounds perfect.
Old 04-04-2004, 08:48 AM
Travis  is offline
Posts: 30  -  iTrader: (0)
I swapped out the sotck V pickups for a Duncan Custom/Jazz set. I was much happier with the Duncans. My two cents.
Old 04-05-2004, 06:52 PM
analogcreature  is offline
Posts: 179  -  iTrader: (1)
when i get my 1527, i want to stock it with pickups so i can get a nice thick edgey tone liek Petruccis on the Awake album. i absolutely do not wnata thin sound at all though, so i dont know what kind of pickups i should get, im using an evo7 in my 7620 rite now, but i think i like the sound im getting from Awake more than the evo7. any suggestions? remember, thick, edgey, NO THIN SOUND, lots of tone
dimarzio blaze, fender princeton, fender princeton chorus, neck pup, string guitars
