Old 03-10-2005, 02:48 PM
Roland  is offline
Posts: 617  -  iTrader: (0)
String gauges?
After having searched the forums for a suitable topic, I found that this particular, rather individual, question needs its own thread.
I've got an RG7321, and I love it. The sole gripe I have with it (It's strung with D'Addario's) is that the factory-supplied low B-string is sloppy - doesn't fit well for hammers/pulls, buzzes against the fretboard (fixed this by pulling action further back and higher) and has a generally loose tension that makes it harder to play fast. So therefore, I'm asking you all what string gauge I should change it to. Problem being, I don't know the gauge of it... but if it helps you helping me, I'd like it to have the same tension as a low E regularly has, meaning TIGHT.
Thanks in advance.
NOTE: I only want to replace the low B.
Old 03-10-2005, 03:22 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Re: String gauges?
Try a .56 or a .58. For me, I think a .58 is about right for a 7, but honestly, you're probably better off starting with the .56 and then seeing if it still feels a little too light.
-D
Old 03-10-2005, 05:37 PM
The Dark Wolf  is offline
Posts: 688  -  iTrader: (1)
Re: String gauges?
-D
Agreed.
If you're tuning to A or lower, look into a .060 or more. Lotta people get good results with a .070.
Old 03-14-2005, 12:40 PM
fishhead785  is offline
Posts: 176  -  iTrader: (1)
Re: String gauges?
i use D'AddarioXL10 on all my 7 strings that are tuned standard and on my 1077XL that is tuned a d a d g b e I use .011 gauge with a .060 for the low b
Old 04-05-2005, 05:44 PM
tone_connoisseur  is offline
Posts: 147  -  iTrader: (0)
Re: String gauges?
I'm getting my 7 string in just a couple of days. That's good info to know. Thanks.
Old 04-05-2005, 09:45 PM
Johnmetall  is offline
Posts: 18  -  iTrader: (0)
Re: String gauges?
Ibanez 7 strings come stock with 9-54...it is kinda wierd that your b string is sloppy...It may be due to the fact that you may be down tuning your guitar... on standard tuning in all my guitars the B's are pretty tight..as I matter of fact I usually set my guitar 1/2 step down which gives me a loose feeling on the string which I play faster....
the string size is a personal thing like your picks and your pickups...what works for other may not work for you...
Old 04-05-2005, 10:03 PM
jski7  is offline
Posts: 172  -  iTrader: (1)
Re: String gauges?
.10-.60 works well for one whole step down (ADGCFAD) . A thorough set-up may help as well (if you haven't yet). Hope this helps !
Old 04-05-2005, 11:09 PM
revsharp777  is offline
Posts: 980  -  iTrader: (1)
Re: String gauges?
I used a 56 for years, but recently I bumped up to a 60. It works very well for B and A tuning.
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
Stock string gauges on RG prestiges? func J-Custom, USA Custom & Prestige Ibanez Guitars 4 01-25-2005 10:10 PM
String gauges: 009 or 010? Pesso Tech: Setup, Repairs and Mods 10 12-08-2002 03:56 AM
String gauges (HELP me!) juha Tech: Setup, Repairs and Mods 6 09-30-2002 06:33 AM
Experiences with different string gauges on edge-guitars LennyNero Tech: Setup, Repairs and Mods 1 08-20-2002 06:25 AM
