Other 7-string Guitars
String gauges
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
08-20-2006, 11:29 AM
NeglectedField
Posts: 945 - iTrader: (
String gauges
Which
string gauges
do you guys use on your 7s if not the standard 9-54, and how many of you needed to have truss-
rod adjustment
as a result of changing gauges?
NeglectedField
Find all posts by NeglectedField
08-20-2006, 01:23 PM
eelblack2
Posts: 865 - iTrader: (
Re: String gauges
You will almost certainly need a
truss rod
crank if you shift guages for maximum playability - especially if your neck is of the somewhat thinner Ibanez or similar variety. Anytime I shift guages on a given guitar, the first think I look at is neck, then tremolo if applicable. Often its a matter of adjusting both in tandem until you get the straightness and lowness of action that is desireable.
eelblack2
Find all posts by eelblack2
08-20-2006, 01:39 PM
Drew
Posts: 4,538 - iTrader: (
Re: String gauges
Pretty much what eelbkack said. A
truss rod adjustment
, once you get your head around what you're doing, is actually a pretty simple tweak so don't let that scare you. Re-adjusting the spring tension on the bridge is actually the harderst part of a
string guage
change, IMO.
Personally, I use an Elixer 10-46 set. I've been using a .56 B for a while now, but I think that's even slightly too light for 9's, much less 10's (.58 is my preferred guage for a set of 9's, it balances pretty well against the E). Since Elixer doesn't offer anything between .56 and this, I've got a few .68's in the mail. My Hellraiser has, I believe, a .70 on it right now from the duyde I bought it off, and even with the longer scale it's pretty manageable. Meanwhile the .56 on my UV feels like a joke, it just flops too much under a moderate pick attack compared to the low E.
I think a .54 B (much less a .52, which I've seen on occasion) is ABSURDLY light.
Drew
Visit Drew's homepage!
Find all posts by Drew
08-20-2006, 07:06 PM
HoP
Posts: 143 - iTrader: (
Re: String gauges
I tune to standard A, and I use 10-60
dean markley blue
steels
HoP
Find all posts by HoP
08-20-2006, 07:46 PM
NeglectedField
Re: String gauges
Drew
Pretty much what eelbkack said. A truss rod adjustment, once you get your head around what you're doing, is actually a pretty simple tweak so don't let that scare you. Re-adjusting the spring tension on the bridge is actually the harderst part of a string guage change, IMO.
I have a 7321 so I don't have to worry about trem issues. Having only had it for a week or so it's still on 9-54, very light and sloppy especially on the
lower strings
but quite fast. I was thinking (if I do choose new gauges) of going for a 9-46 + 56 for the B, but I'm not sure if that'll cause bowing in the neck. Or possibly going for 9, 11, 16, 24, 36, 46, 56...
NeglectedField
08-20-2006, 08:19 PM
HoP
Re: String gauges
trussrod adjustments are simple and its something that must be done. dont pick your guage of string because of truss rod issues.
HoP
08-21-2006, 10:40 AM
Roland
Posts: 617 - iTrader: (
Re: String gauges
GHS Boomers, 10-60. Works wonders, in my opinion. And I'll chime in on the above post: truss-rod adjustments are easy, by no means should you choose gauge because of the truss-rod.
Roland
Find all posts by Roland
08-22-2006, 02:14 AM
stretcher7
Posts: 180 - iTrader: (
Re: String gauges
9-54 on
thicker necks
. 9-56 on thinner ones.
stretcher7
Visit stretcher7's homepage!
Find all posts by stretcher7
08-22-2006, 04:33 AM
toshiro
Posts: 1,812 - iTrader: (
Re: String gauges
I've got 9-46 +60 on my Schecter tuned to Bb.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
08-22-2006, 09:20 AM
Brord
Posts: 11 - iTrader: (
Re: String gauges
11-50+68/70 Tuned to A standard
Brord
Find all posts by Brord
10-27-2006, 11:12 PM
heavy7-665
Posts: 17 - iTrader: (
Re: String gauges
13-52 +70 tuned G standard on a 7321 but i don't think i need to touch the truss rod sounds fine and i don't know how
heavy7-665
Find all posts by heavy7-665
10-27-2006, 11:15 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: String gauges
heavy7-665
Wow, that's low and heavy.
jaxadam
Find all posts by jaxadam
10-28-2006, 10:11 AM
fettouhi
Posts: 9,937 - iTrader: (
Re: String gauges
jaxadam
+1
Regards
André
fettouhi
Find all posts by fettouhi
10-28-2006, 10:27 AM
Planeflux
Posts: 210 - iTrader: (
Re: String gauges
EDIT: just realized I posted 6-string gauge sets in a 7-
string section
10:33 AM
. Reason: wrong section
Planeflux
Find all posts by Planeflux
10-28-2006, 12:31 PM
Roland
Re: String gauges
A set of GHS Boomers 10's with an added 52 for low E and 68 for low B, tuned to A standard.
Roland
dean markley
dean markley blue
dean markley blue steel
ernie ball
lower strings
markley blue steel
rod adjustment
strapping young lad
string gauges
string guage
string section
thicker necks
truss rod
convert 7 string to 6 string?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
String Gauges For RG 7321!! NEED HELP!!!
Memq
11:16 PM
String Gauges on my 1527
Unknown Doodl3.2
05:24 PM
Yet another poorly mixed song by your truly
IbanezroadstarII
33
03-16-2006
10:01 PM
Stock string gauges on RG prestiges?
func
10:10 PM
Experiences with different string gauges on edge-guitars
LennyNero
Tech: Setup, Repairs and Mods
06:25 AM
07:00 PM
