Other 7-string Guitars
Strings for drop C tuning
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
10-27-2004, 03:38 AM
Wound
Posts: 312 - iTrader: (
I've joined a new band who plays drop C tuning. I used my Gibson 6 string with a standard 010 - 052 set, but I find the strings too floppy. I want to start using my AX7221 because of better sound. Right now I have a 060 bass-string on the bottom and a standard 010 - 052 set on the other 6 strings. I tuned these to a drop C tuning, but I'm scared that these strings will be too tight for the neck. I had problems with this doing drop A tuning om my Gibson 6 string. Anyone have any recommendations for what strings I can use on my AX7221 without having too much tension on the neck, and without the strings getting too floppy?
Hope this wasn't too confusing heh
Thanx
Kim c",)
Wound
Visit Wound's homepage!
Find all posts by Wound
10-27-2004, 04:13 AM
BlueGrot
Posts: 132 - iTrader: (
Is it a
Les Paul
? Then the 060 should be adequate, maybe you need a
truss rod adjustment
, but it tightens up the sound atleast.
And a 52 for the low G? That sounds a bit thick
BlueGrot
Find all posts by BlueGrot
10-27-2004, 05:10 AM
Wound
Yea the 060 for the C on my AX felt fine, but yea the 052 for G was really tight, what set would you recommend for the rest of the strings?
Wound
kp69
Posts: 82 - iTrader: (
I usually use a set of 11-50 for D standard.....anyting less and the strings feel loose-particularly for my picking hand.
On drop C I'll use a set of 11's like above and then replace the 6th string with a 52 or 54.......but this is all on a 25.5 inch scale guitar.
kp69
Find all posts by kp69
10-27-2004, 05:23 AM
Wound
Yea this is for my 7 string AX7221 so I think i'll stick with a 060 on the bottom, but not sure what set to get for the last 6 strings.
Wound
10-27-2004, 05:25 AM
BlueGrot
Wound
I`d recommend a set of
009 G <--- High G, this is what you meant, right?
012 D
016 A#
028 F
038 C
048 G
060 C
BlueGrot
10-27-2004, 06:05 AM
Wound
yea that looks good, thank you :-D
Wound
10-27-2004, 08:02 AM
ibanezlover
Posts: 215 - iTrader: (
Hey Wound, have a look at
Ernie Ball
's Beefy Slinkys. They are 11 gauge.
ibanezlover
Find all posts by ibanezlover
10-27-2004, 05:07 PM
Two hands31
Posts: 4,989 - iTrader: (
I know there's a company that makes strings specifically for low-tunings, and they have one designed for drop-C that has a .60 on the low-C. You could use that, and add something thin for the high string of your choice.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
10-27-2004, 05:28 PM
toshiro
Posts: 1,812 - iTrader: (
Everly(
www.everlymusic.com/
) "X-rockers", and they're even damn good strings to boot.
Their C# tuning set is: .012 .016 .022 .038 .048 .060 ... Seems really tight to someone like me, who would use 10-52 strings in D or Db(C#)..
Personally, you could probably get away with a set of 9-46(.009 .011 .016 .026 .036 .046) strings and a low 58 or 60 added to it, they would much easier to find than making your own custom set.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
10-27-2004, 05:38 PM
Two hands31
I use 10-52s and a low 60 for my 7-string, and I sometimes tune everything but the G up a half-step (basically C-standard with an extra high string). So yeah, a standard set of 10s, or probably better 9s or lighter should work for drop-C with an extra high string.
Two hands31
10-28-2004, 11:21 AM
Drew
Posts: 4,538 - iTrader: (
there's also that GHS
Zakk Wylde
set... Forgot the guages, but it's for, what, Drop-B?
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
10-28-2004, 01:54 PM
Wound
Two hands31
Yea I have a standard 10 - 52 set plus a low 60 bass-string on my AX for my drop A tuning. I tried to tune it to drop C, but the strings were really tight so I'm scared I'll **** up the neck. So I think i will try the 09 - 46 set with the low 60 bass string, casue the low 60 string felt fine tuned to C.
Wound
ernie ball
les paul
rod adjustment
truss rod
zakk wylde
how to do drop f tuning
what guitar strings do the pros use
how to tune to drop c with a zr trem
what strings do you use for PRS
what kind of strings does korn use
04:16 PM
