Other 7-string Guitars
trem angle trouble
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
07-07-2004, 11:17 PM
analogcreature
Posts: 179 - iTrader: (
trem angle trouble
hey y'all, i put on a .58, and a set of 9's on my RG1527 a few hours ago, i originally had a 9-54, the same as stock size ibanez. anyway, my trem angle is way high, action IS where i want it about, but the angle is too high up from the cavity, i was wondering, since the claw is already screwed in up to where the threaded screw part stops, if i can screw more into it to pull it down into the body without damage or bad stuff happening to my new $600 guitar
analogcreature
Find all posts by analogcreature
07-07-2004, 11:57 PM
Akhenaten
Posts: 728 - iTrader: (
Replace or add springs...Considering I use a 10-52 set with a 60 on a long scale, a piddly 58 shouldn't have raised it that much. Possibly weak springs. Try replacing them, or add one and see what's up. If the claw is screwed in that far, I don't know what else could be wrong.
Akhenaten
Find all posts by Akhenaten
07-08-2004, 01:28 AM
Posts: 19,348 - iTrader: (
Some of the screws thread the whole shaft, some stop 1/2" from the head. Either way screw it in as far as you need to.
07-08-2004, 04:28 AM
Jem7RB MK
Posts: 2,341 - iTrader: (
Re: trem angle trouble
analogcreature
Just to add my tuppence (love that word) and to echo Rich, out of the 5 or 6 7 string ibanez i have owed, all have been screwed in PAST the thread end, this is no big problem, and is totally safe from all points of view, Just grab a screwdriver and sort the angle out :-)
HTH ... BTW both my UV and RG7Custom are screwed to about 2 or 3 mm away from touching wood with .10's and a bottom .60 ... All my guitars have 3 springs, always :-)
Rob
Jem7RB MK
Find all posts by Jem7RB MK
07-08-2004, 05:41 PM
analogcreature
ok thanks everyone for your help, i screwed in teh claw a bit more and tuned up and after the second run thru teh strings, everything was in tune, low action, perfect trem angle. im a happy camper
analogcreature
07-08-2004, 07:47 PM
Societysucks
Posts: 202 - iTrader: (
I think Ibanez should start setting these things up with stock guage 10's.
I don't know what gague the masses use, but I find 9's a pain in the neck.
My 1527 took a me a while to set up too.
Societysucks
Find all posts by Societysucks
07-09-2004, 11:13 PM
analogcreature
Societysucks
i actually like the 9's on all my strings but then a heavier .58 on my low B for that meatier tone
analogcreature
what trem is on the rusty cooley
how to set up fender trem
how to tighten zr trem
How to block ibanez trem
is my edge trem bar in all the way
02:35 AM
