Other 7-string Guitars
TRS, Lo Pro, Edge trem cavities
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
04-28-2005, 01:39 AM
tone_connoisseur
Posts: 147 - iTrader: (
Are all trem cavities routed the same? Whether it be for an Edge, or Lo Pro, or TRS trem? What I thought was a 7620 is actually a 7420, and I ended up buying the wrong parts. If the routing is the same I'll just order a new Low Pro trem. Thanks!
tone_connoisseur
Find all posts by tone_connoisseur
04-28-2005, 02:41 AM
Cedric777
Posts: 223 - iTrader: (
Re: TRS, Lo Pro, Edge trem cavities
I dont think they are the same .... you cant swap lo pro to edge pro but not TRS to edge or lo pro ...
That's what i believe but wait for the others...
ciao
Ced
(sorry im french translation is bad and poor from what i want to say ...)
05:35 AM
Cedric777
Find all posts by Cedric777
04-28-2005, 04:11 AM
bpd111
Posts: 1,628 - iTrader: (
They are not the same...
bpd111
Find all posts by bpd111
04-28-2005, 07:47 PM
Jemmm
Posts: 426 - iTrader: (
you can swap lo pro to edge pro but not TRS to edge or lo pro ...
Is this correct??? I have always thought you could swap Edge Lo Pro with the Edge model. No Edge/Edge Lo Pro to Edge Pro. That's completely different animal. TRS to OFR is possible. TRS to Edge/Edge Lo Pro might require some routing.
Jemmm
Find all posts by Jemmm
04-28-2005, 07:57 PM
Flobanez
Posts: 5,513 - iTrader: (
My UV7PWH and RG 7620 have the L
Pro Edge
and my S 7420 has the TRS.
I wanted to replace the TRS on my S with a Lo Pro Edge....
but sadly it's not going to happen.
Flobanez
Visit Flobanez's homepage!
Find all posts by Flobanez
04-29-2005, 05:22 AM
fettouhi
Posts: 9,937 - iTrader: (
Flobanez
My UV7PWH and RG 7620 have the L Pro Edge and my S 7420 has the TRS.
Then just replace it with an OFR, that's just a choice.
Regards
André
fettouhi
Find all posts by fettouhi
04-29-2005, 05:29 AM
toshiro
Posts: 1,812 - iTrader: (
Nothing but an Edge Pro will swap for an Edge Pro, the intonation point is different from every other tremolo on the market, Ibanez included. YOu also can't put the Edge Pro in a body that wasn't designed for it.
The Edge and Lo-Pro Edge are interchangable with each other.
The TRS rout is different from the Edge/Lo-Pro Edge rout, and you have a 10% chance of an Edge fitting in without having to rout, 90% of the time you'll need to remove some wood. The OFR and OFR-7 should fit the TRS rout though, and are a much better trem than the TRS.
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
04-29-2005, 05:35 PM
damo7v
Posts: 1,150 - iTrader: (
just to further confuse the issue, i asked recently about replacing an EP2 with anything good/better.
never did get a response.
is there a resource that outlines the physical dimensions of these trems and their routings? maybe a table of what (if any) are interchangeable?
that'd be great, and probably save a heap of quesions.
damo7v
Find all posts by damo7v
04-29-2005, 05:54 PM
fettouhi
The reason why nobody responded to your question is that nobody knows. From what I have read the Edge Pro and II/III are not interchangeable. The same applies for the switch to Edge and Lo Pro Edge. Then the last thing would be to go to a OFR or Gotoh FR, there I don't know the answer.
Somebody needs to try this and then report back here. Now who is going to be the first test person
Regards
André
PS. In the end you should be able to swith to any trem (mentioned above) is might then require routing of some sort (everything mentioned above assumed that no routing needed to be performed).
fettouhi
04-29-2005, 07:17 PM
adamcbest
Posts: 870 - iTrader: (
i may have read this wrong.. but i think on LGM's site, a trs to
edge trem
rout ws listed in the services and it was only like 30 bucks. if you have an s 7 string you want to be an edge model.. i'd send it to him. 30 bucks for the rout is more than worth it. look into it. I think the trs routing of the latest s 7 string was the downfall of that model. i'd rather have the edge 7 than an OFR 7
adamcbest
Find all posts by adamcbest
05-01-2005, 01:27 PM
fettouhi
adamcbest
i may have read this wrong.. but i think on LGM's site, a trs to edge trem rout ws listed in the services and it was only like 30 bucks. if you have an s 7 string you want to be an edge model.. i'd send it to him. 30 bucks for the rout is more than worth it. look into it. I think the trs routing of the latest s 7 string was the downfall of that model. i'd rather have the edge 7 than an OFR 7
Only problem with sending it to LGM is that he doesn't do these small jobs anymore because he's so backed up at the moment.
Regards
André
fettouhi
05-01-2005, 01:49 PM
JTM45
Posts: 1,008 - iTrader: (
There's a tutorial here about changing from a TRS to an Edge/Lo-Pro but it requires routing and all sorts.
http://www.projectguitar.com/tut/trs2lopro.htm
JTM45
Find all posts by JTM45
edge trem
pro edge
will edge zero pro fit edge 3 route?
what trem is on the rusty cooley
how to tighten zr trem
Can you replace an edge trem with a LoPro Edge? - Is it poss
Cycovision
Tech: Setup, Repairs and Mods
01:22 AM
Edge III swap for another Edge model trem?
lespaulreedsmith
36
03-14-2009
06:10 PM
Need to replace original Edge trem posts ... many questions.
JohnnyRasgueado
12:34 PM
RG550 and Edge problems with the Edge trem, please advice
LaXu
05:38 PM
05:37 PM
