Other 7-string Guitars
Unknown Ibanez 7 string.
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
12-29-2002, 11:56 PM
Scoff X
Posts: 211 - iTrader: (
Huge question
Friend wants to sell me another 7 string (Have a UV now)
He doesn't know what model it is. I think its a 7421 but i also saw a 7321.
Color is Magenta Crush. SN is F9939285
He is selling it for like..$200 originally $550. So if ANYONE has an input, please respond.
(I don't think it is a HIGH quality guitar like my UV and custom strat..but how does it rank with you guys?)
Scoff X
Find all posts by Scoff X
12-30-2002, 12:08 AM
BucketBot
Posts: 680 - iTrader: (
I don't think the 7421 or the 7321 was availible in magenta crush and the 7321 was made no earlier than 2001(since the serial # shows it to be a '99).
Dose it have the
fixed bridge
? I think the only one in magenta crush would be a 7420 which has the LoTrs7 bridge.
Either way, if it's in decent shape, for $200 you can't really go wrong.
BucketBot
Visit BucketBot's homepage!
Find all posts by BucketBot
12-30-2002, 12:12 AM
dcord
Posts: 1,077 - iTrader: (
The '99 serial number makes it probably an RG7421 in Cherry Fudge if it has a fixed bridge. If it's got a locking trem, then it's either an RG7420 in Magenta Crush, or a 7620 in Vampire Kiss.
$200 is a steal.
~d~
dcord
Find all posts by dcord
12-30-2002, 01:28 AM
Scoff X
Mid 99 says that the 7421 started.
http://jemsite.com/axes/htm_features/spec_ib7.htm
Scoff X
12-30-2002, 08:01 PM
Scoff X
ehhh???
TTT
Scoff X
12-31-2002, 12:57 AM
Scoff X
i went ahead and got it....
Now here is a question. I think it originally had 9s on it, and i put 10s on it. What do i need to do ? Will it mess it up ? I usually have the guitars setup but I wanna do this on my own
Scoff X
12-31-2002, 11:55 PM
EKG
Posts: 2,280 - iTrader: (
With a different guage string setup on a
fixed bridge model
, the only thing you really have to worry about is probably intonation ;-)
EKG
Visit EKG's homepage!
Find all posts by EKG
01-01-2003, 02:38 AM
darren wilson
Posts: 4,190 - iTrader: (
And maybe a little bit of
truss rod
tweaking.
darren wilson
01-01-2003, 03:00 AM
Scoff X
Its setup
Pickups HAVE to go. Suggestions?
Scoff X
01-01-2003, 12:33 PM
PlayThickStrings
Posts: 28 - iTrader: (
Scoff X
Its setup
Can you do me a favor? I'm in the same boat tha tyou were a little bit ago, buying an unknkown 7 string that MIGHT be a 7421, but is most likely a 7621.. Can you tell me what markings/identification/model number might be either stamped on, or a sticker on the back of those pickups???
PlayThickStrings
Find all posts by PlayThickStrings
01-01-2003, 02:18 PM
EKG
There should be a stamping in the neck pocket for identification.
Pup choices? EMG's!
EKG
01-01-2003, 02:21 PM
PlayThickStrings
Eddie Kolesar
Pup choices? EMG's!
Well, that's cool and all, but I don't think the guy I might buy this from is going to want me to remove the neck. What about the pups, is there a sticker or marking on the dimarzios that will let me know? The 7421 (according to research I've done on this site) used a cheaper hotter
output pickup
to cut costs. So I'd assume if I just pull a pickup out of
the cavity and look at the back, I'd be able to determine what this thing is from that?
PlayThickStrings
01-01-2003, 02:26 PM
EKG
Sure, if you can pull the pup(s), there should be an ID number. Also, I'm not sure but the 76's were made in Japn....the 74's were made in ?
EKG
01-01-2003, 02:29 PM
PlayThickStrings
Eddie Kolesar
According to this site, in the comparison table thing, the 7421 and 7621 were both made in Japan. If I knew for sure that the 7421 was made in Korea, then I'm home free...
When you say ID number, WHAT ID number am I looking for? The pickups are called Dimarzio NEW 7?? Do you know the DP number?
Sorry for being anal, but if this thing IS a 7421, I don't want it.
PlayThickStrings
01-01-2003, 02:49 PM
Scoff X
Ill tell you this. I got the 7421 and so far, it plays just as well as my universe. A bit lighter perhaps. Setup the exact same way. Same action and all basically.
I have played the 7620 and 7621, and to be 100% honest, there isnt much of a difference, espacially if youre going to switch out the pickups.
Scoff X
fixed bridge
fixed bridge model
neck finish
neck pup
output pickup
strap button
strap buttons
truss rod
convert 7 string to 6 string?
ibanez zps dont flutter?
compare ibanez grx40 squier telecaster affinity
how to fix string buzz ibanez lock nut
10:35 AM
