Old 07-05-2004, 04:15 PM
srg  is offline
Posts: 10  -  iTrader: (0)
Washburn WG587 neck dimensions.
Does anyone know the neck dimensions on the washburn wg587?
I'm thinking of buying one of those.. or the ibz rg7321, but i havn't tried the washburn neck.
Old 07-09-2004, 11:27 AM
jwoods986  is offline
Posts: 378  -  iTrader: (5)
I bought one and I'm not sure what the dimensions are but the neck is definitely thicker than an Ibanez (I used to have a 7420), but still comfortable. I will tell you, the pups in the WG are much better than the v7/v8s in the lower model RGs. I would recommend the WG over the 7321 or even a 7421 (assuming you're looking for a fixed bridge). If you find a good deal on a used 7621, go for it. Otherwise, it sounds like you're looking in the sub-$300 range also, go for the Washburn.
Old 07-16-2004, 09:35 PM
srg  is offline
Ah, thanks :]. I'll probably be picking up that WG next week.. with floating bridge though.
Luuv a thick neck.
fixed bridge, neck dimensions
