Old 08-13-2004, 11:23 PM
Ibanut  is offline
Posts: 223  -  iTrader: (2)
will an Ibanez 7 string neck fit a jackson
Well will it? Jacksons are 22 fret I dont know if Ibanez has 22 fret neck..
Old 08-13-2004, 11:26 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
Nope, most Ibanez 7-strings are 24-fretters. With the exception of I think the short-lived S-series 7-string.
Old 08-14-2004, 11:15 PM
Jeff  is offline
Posts: 1,501  -  iTrader: (1)
The cheaper Gio 7 string had a 22 fret neck as well I believe. I like the neck shape on my Gio a lot, so you might want to check it out!
Old 08-15-2004, 12:17 AM
trajectory fish  is offline
Posts: 394  -  iTrader: (0)
Don't forget the AX7 http://filebox.vt.edu/users/bchaney/public/CUSTY.JPG :P
Old 10-02-2004, 11:01 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
NOPE.
Old 10-03-2004, 05:38 AM
Shakma!!  is offline
Posts: 291  -  iTrader: (2)
Originally Posted by jemaholic
NOPE.
Proclamation upheld.
Old 10-03-2004, 12:07 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
As a Cuban auto mechanic once said, "Does it fit? Everything fits!"
That is to say, yes, it will fit, but not without significant modification to the body and/or neck. Don't forget that most Ibanez necks also come with the All-Access Neck Joint, which mates up to the body in a different way than standard plate-mounted square-heel bolt-on neck joints.
Old 10-04-2004, 01:14 AM
rory  is offline
Posts: 102  -  iTrader: (0)
Not to mention that 7-string neck joints vary even more than 6-string joints...
access neck joint, darren wilson, fret neck, ibanez neck, ibanez necks, neck joint, neck joints, neck shape
