Other 7-string Guitars
Will An RG7321 fit in my RG2550E's Hardcase?
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
08-29-2005, 05:36 AM
Kipperfetish
Posts: 54 - iTrader: (
Im pretty sure the bodys are the same size but the neck is wider (fretboard way) on the 7 string. Would it fit in the case for my 6 string RG? I see that oibanez dont make a special 7 string case so i guess they use the same one. Would it fit?
Kipperfetish
Find all posts by Kipperfetish
08-29-2005, 06:21 AM
King Knall
Posts: 2,445 - iTrader: (
Re: Will An RG7321 fit in my RG2550E's Hardcase?
Ibanes does make a case that for 7 strings. It's called the UV1000. But the J-Craft case even fits the Universe and K7, so maybe it will work.
King Knall
Find all posts by King Knall
08-29-2005, 06:26 AM
Kipperfetish
do the UV's and K7's come in J craft cases?
Kipperfetish
08-29-2005, 06:47 AM
King Knall
For the 2005 models I think, 'cos the Jems do. Maybe I'm wrong. Anyone can help here?
King Knall
08-29-2005, 06:57 AM
learningtolive
Posts: 178 - iTrader: (
My 7321 fits perfectly in the M100C (is that right?) case that came with my RGT3120. The wide fretboard fits like a glove, and the extended headstock has just enough room.
Hope this helps
learningtolive
Find all posts by learningtolive
08-29-2005, 07:18 AM
King Knall
See! I should have been more clear. The J-Craft is a basically M100C for the Japanese Prestige and Signature models.
King Knall
08-29-2005, 10:50 AM
mi2tom
Posts: 7,522 - iTrader: (
It should I think ......
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
08-29-2005, 05:20 PM
Munky7
Posts: 139 - iTrader: (
ya my 7321 came with a m100c and it fits literally perfect all around
Munky7
Find all posts by Munky7
01-06-2009, 03:48 PM
jesusrocker316
Posts: 35 - iTrader: (
Munky7
I don't mean to be rude and accuse you of lying, but I've called several places and talked to "tech pros" online at *************** and guitar center and they all said that ONLY the UV1000 would be able to hold an RG7321. I already have a m100c and it would save me $140 to be able to use it...
I want to believe you, but just in case, would you mind measuring the length of the headstock? I would sincerely appreciate it
jesusrocker316
Find all posts by jesusrocker316
01-06-2009, 03:49 PM
jesusrocker316
jesusrocker316
Oh, and in inches, not mm
jesusrocker316
01-06-2009, 03:59 PM
guitardevil2005
Posts: 442 - iTrader: (
jesusrocker316
i have an rg7421 and it fits PERFECTLY into what i think is an older m100 case. i got the case used when i bought my rg570 but use it with my 7s instead.
-MAttV
guitardevil2005
Find all posts by guitardevil2005
01-06-2009, 04:13 PM
GazTop
Posts: 172 - iTrader: (
jesusrocker316
As a helpful tip google can recalculate pretty much any measurements into other units of your choice.
Just type for example:-
"430mm to inches" and hit enter and google will give you the answer.
GazTop
Visit GazTop's homepage!
Find all posts by GazTop
01-06-2009, 05:35 PM
jesusrocker316
so what was the original measurement?
jesusrocker316
01-06-2009, 05:37 PM
jesusrocker316
GazTop
So what was the original measurement of the headstock?
jesusrocker316
01-07-2009, 12:29 PM
MattyB
Posts: 61 - iTrader: (
I tried my 7321 in my J-Craft case (which holds my JEM UVWH ) and it don't fit...
MattyB
Find all posts by MattyB
where is rg7321 made?
rg7321 indonesia?
how good is hte ibanez hardcase
what is the string gauge ibanez rg7321
how to ship a guitar hardcase from usa to europe
Recommended (preferrably) combo-amps to use with an RG7321?
Roland
12:38 PM
fs Ibanez rg7321
gunkungfu
03:01 PM
RG7321 or GRX720
IbanezroadstarII
12:23 AM
Ibanez RG7321 question
eemeli
02:45 PM
RG7321 made in Japan? - i thought these were korean made?
reguv760
08:54 AM
08:30 AM
