Old 02-21-2007, 02:35 PM
zEr0  is offline
Posts: 1,223  -  iTrader: (18)
10's with only 3 springs = POSSIBLE? (backstop)
I just bought a backstop from a fellow jemsiter and am quite eager to install it. However in order to do so, I need to switch from 4 to 3 tremolo back-springs. Unfortunately, I use a 0.10 / 0.49 string set which is quite stiffer than your usual 0.09 set and I can't seem to balance my trem with only 3 springs (they cannot be installed in a pyramid fashion either). Anyone run into this problem before? I'm guessing it's either downtuning or moving down to niner's but I figured I'd ask and see if someone knows some way around this.
THX
Old 02-22-2007, 02:04 PM
wildrat666  is offline
Posts: 66  -  iTrader: (0)
Re: 10's with only 3 springs = POSSIBLE? (backstop)
try with new fresh springs
Old 02-22-2007, 03:35 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
All of my Edge-equipped guitars currently have 10s with three springs and it's no trouble at all. The claws are screwed in just about as far as they can possibly go, but it works fine.
Old 02-22-2007, 04:44 PM
i have 010-052 strings on my guitar and my springs are far from being all screwed in. I tune down 2 steps maybe that is the reason. But try fresh springs or add one more.
Old 02-22-2007, 06:18 PM
JTM45  is offline
Posts: 1,008  -  iTrader: (1)
The standard Ibanez springs are 52mm long but they also sell 47mm springs.
If you got 3 of those shorter springs they would probably give you as much tension as your 4 regular springs.
By the way,what guitar are you fitting the backstop to ?
The reason i ask is because it will onyl fit in certain Ibanez guitars.Most of the newer Edge-Pro equipped models don't have enough space in the spring-cavity route for the backstop to clear the springs and the cavities are generally routed at an angle whereas the backstop should ideally be mounted on a flat surface.
Old 02-22-2007, 06:32 PM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
10s on all mine too, stock springs arranged in parallel, and yes the claw is screwed in a long way, but I've had no problems with it.
Old 02-23-2007, 05:42 AM
Texter  is offline
Posts: 839  -  iTrader: (0)
The Backstop keeps the trem from going back...not up...
Old 02-23-2007, 07:14 AM
chlamy  is offline
Posts: 283  -  iTrader: (0)
Two JEMs and a UV, all with 10/46s (+56 on UV), three springs parralel, not a problem, and springs not completely screwed in
Old 02-23-2007, 10:31 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
I use 10's and have never had the need to use more than three springs.
Old 02-23-2007, 10:59 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
yeah over 3 seems overkill to me for 10's
Old 02-23-2007, 11:07 PM
ibanezdiehard  is offline
Posts: 764  -  iTrader: (1)
i have never used more than 3 springs.
i use 10-56, but i seem to get better tension when i put the springs in a arrow formation.
Old 02-24-2007, 04:37 AM
zEr0  is offline
THX for the input guys.
ATM My backsprings are set all the way back and the trem is still a bit too high. Even if I could get the LO-PRO to stabilize in a decent position I wouldn't be playing this axe since the trem has a very weird feel (which I don't like) due to the spings being stretched all the way.
I'll be going back to 0.09's and probably tuning up half a step. I've always wanted to try the bite of thin strings with the feel of harder tension.
Old 04-02-2007, 11:12 AM
Ikonoklast  is offline
Posts: 12  -  iTrader: (0)
I use a guitar with .11s in C standard with only 2 springs and the setup works just fine
Old 04-04-2007, 04:22 AM
Okan2  is offline
Posts: 20  -  iTrader: (0)
I use .10-.52's and I couldn't manage to balance them with 3 standard springs, so I ordered extra hard ones from an online store (German). They just worked out perfect. I have the claw screws less buried in than they would be with a .09-.46 set with the standard springs...
Old 05-17-2007, 02:35 PM
shogun  is offline
Posts: 1,525  -  iTrader: (13)
Wink
in c standard........
claw screws, equipped guitar, ibanez guitars, local luthier
How many springs is necessary for Lo Pro Edge Tremolo? Jeffy Lion Tech: Setup, Repairs and Mods 1 05-27-2008 03:41 PM
backstop vs esp arming adjuster newbieguitarmaker Gear and Equipment 12 01-31-2008 05:57 AM
Trem Springs Chud Tech: Setup, Repairs and Mods 2 02-26-2006 04:02 PM
Offset 4 springs dex Tech: Setup, Repairs and Mods 1 02-17-2004 07:41 AM
JEM 7DBK - why 4 trem springs? pseudomarine Tech: Setup, Repairs and Mods 1 02-20-2003 09:31 AM
