Tech: Setup, Repairs and Mods
22 fret vs 24 fret
05-14-2006, 05:00 PM
Ant1981
Posts: 2,181 - iTrader: (
22 fret vs 24 fret
Would a 22
fret neck
work on an RG body or would there be intonation problems where there should have been a 24 fret?
Ant1981
Find all posts by Ant1981
05-14-2006, 05:07 PM
Ironjose
Posts: 1,060 - iTrader: (
Re: 22 fret vs 24 fret
i´d guess there be no problem... but i´m not expert, dont know if the scale has something to do.
JJ
Ironjose
Find all posts by Ironjose
05-14-2006, 05:17 PM
ibanez2005
Posts: 910 - iTrader: (
The
bridge position
may be an issue as far as intonation goes. Every guitar is different, the bridge aint gonna always be in the same place, like trying to put a strat neck on a
les paul
, dunno if it would work.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
05-14-2006, 05:19 PM
elcid
Posts: 8,718 - iTrader: (
I'm betting you will have problems.
elcid
Find all posts by elcid
05-14-2006, 05:24 PM
Ant1981
I've been guessing that the bridge may be differently positioned, as the
neck scale
is shorter, but wondering if anyone else has tried. Yeah, thinking about it, I might run into problems, if i tried it.
Ant1981
05-14-2006, 05:29 PM
Ironjose
you should try it thouhg coz it might work, experimentation is the key
JJ
Ironjose
05-14-2006, 05:31 PM
Ant1981
I'm not sure the intonation could be adjusted that far, I'd be better off finding a 24 fret neck rather than a 22 fret, but I do love 22 frets, got a few of them and just seem to love the look of a 22 fret.
Ant1981
05-14-2006, 05:33 PM
StTan
Posts: 46 - iTrader: (
Look at it this way. You could, theoretically, retrofit extra frets on any neck if there was space allowed to do it without altering the intonation as well as rip of frets to make it a 21 fret or less. As long as the 12th fret is halfway between the nut and the bridge there's no problem. Or get a fretless neck, tune up the strings and play along.
StTan
Find all posts by StTan
05-14-2006, 05:37 PM
Ant1981
Yea you could in theory fit extra frets, but from the nut to the bridge is a different distance. The scale is different. I found this out when I tried to swap cases round from a 24 fret Ibanez to a 22 fret Ibanez, the 24 fret was longer.
Ant1981
05-14-2006, 09:15 PM
rastachild
Posts: 720 - iTrader: (
the 22 fret neck probably will not work. scale length is definitely an issue and you will have major intonation issues. the only way it would work is if the neck that was originally on the rg was a 24 fret neck with the last 2 frets overhanging the heel of the neck. you can tell if there is space between neck pocket and the
neck pickup
(on the body). if the neck pickup is flush against the neck pocket and the guitar was originally fitted for a 24 fret neck, then only a 24 fret neck (without an overhang) will work.
rastachild
Find all posts by rastachild
05-15-2006, 03:47 AM
nickcoumbe
Posts: 2,417 - iTrader: (
Reviews: 34
If they are both aanj then no it wont work.
It might work if it is an older heel joint.
Measure the scale length with the old neck in place, fit the new one and measure again. If the difference is outside half of the adjustment length of your
bridge saddles
, then you will have intonation problems, and it probably just wont work.
nickcoumbe
Visit nickcoumbe's homepage!
Find all posts by nickcoumbe
05-15-2006, 10:23 AM
rty13ibz98
Posts: 1,811 - iTrader: (
34
nickcoumbe
Measure the scale length with the old neck in place, fit the new one and measure again. If the difference is outside half of the adjustment length of your bridge saddles, then you will have intonation problems, and it probably just wont work.
bingo. aanj is the key. the old heel had the 24 fret neck extension on it. much like the 22 on a 21 strat, but with a longer lip. so to make a long story short...no.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
07-11-2006, 12:50 AM
albee1952
Posts: 784 - iTrader: (
Actually, the old neck is interchangeable with any strat type neck but it looks like crap(just saw one on the Bay). I have also taken an old RG 24 fret neck and pulled the 23rd fret and cut thru to make a 22 fret Wizard neck. I have mounted those on a
strat body
and a saber body with excellent results and perfect intonation. The AANJ will not work at all as someone else said.
albee1952
Find all posts by albee1952
bridge position
bridge saddles
fret neck
les paul
neck pickup
neck scale
strat body
how to fix fret board separation
neck what your low action jackson "24th fret"
how to fret level
fret dress how to
27 fret guitars?
fret wear grooves after 9 months
r1lew999
08:45 AM
Yet another poorly mixed song by your truly
IbanezroadstarII
33
03-16-2006
10:01 PM
sliding miter saw or Radial saw for cutting fret slots??
SilverSurfer2
08:54 PM
Fret Buzz from frets 11-14...?
Drew
12:02 PM
Fret Dressing How To - Not for the weak of stomach
Kyle Odom
05:06 PM
04:15 AM
