Old 08-19-2009, 07:52 AM
zarahn  is offline
Posts: 19  -  iTrader: (0)
24.75" Iceman IC300 neck on Jem Jr. body?!?
so I have a Jem Jr333(with dimarzios) and an IC300(with bolt on neck), and I am thinking of putting the IC neck, which is 24.75" scale 22frets, to the Jem body. Is there alot modification need to be done on this setup???how about a 22 frets s-series neck?thanks
Old 08-19-2009, 08:36 AM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Re: 24.75" Iceman IC300 neck on Jem Jr. body?!?
You will have to move the bridge. Quite a lot of work. I wouldn't do it.
Old 08-19-2009, 10:11 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
If they had the same number of frets, then you'd have to move the bridge by
(648 - 629) / 4 = 19 / 4 = 4.75mm TOWARD the neck (648 = 25.5 and 629 = 24.75).
As there are a couple of frets missing, the neck is moved towards the bridge by 2 frets, for 24.75 inch scale this is about 19.25 mm.
This means the bridge needs to be moved AWAY from the neck by about 14.5mm!
This assumes the same length of fretboard after the last fret.
You could leave the bridge where it is (!) and add 14.5mm to the neck as an extension so the neck doesn't go as far in to the neck pocket!!
Jim
NB: please don't take these calculations as read as you'd need to check them before trying, they're just estimates for illustration purposes....
Old 08-19-2009, 12:15 PM
Jemwielder  is offline
Posts: 1,000  -  iTrader: (1)
Reviews: 6
Wouldn't try it. Seeing as a jem is 25.5" (if i recall.) Can't say I blame you. I have an Iceman myself and I love the neck on it. Mines the set neck version though
Old 08-19-2009, 06:17 PM
zarahn  is offline
wow...that's exactly what was expecting!!!better leave it like that.
thanks anyway~
iceman neck, jem jr
FS/FT: Ibanez Iceman IC300 - $220 + S&H or Best Offer Fuzz-Grunge Classified Ads: Guitars and Gear 3 03-11-2010 10:29 PM
WTB: Neck to fit my Jem Body, "Tree of Life", Ebony Board jemeister Classified Ads: Ibanez JEM/UV Guitars 0 08-16-2008 01:34 AM
The "Iceman" and "Rampage" Tomorrow!!! Moibanez Off-topic / Miscellaneous 39 05-27-2007 02:38 AM
WTB Ibanez Iceman IC300 Malakian_Fan Classified Ads: Guitars and Gear 0 08-25-2006 11:43 AM
Iceman "J-Model" sepsis311 Other Ibanez Guitars (including Premiums) 0 05-04-2005 01:32 PM
