Tech: Setup, Repairs and Mods
3rd String-Pinch Harmonics Won't Sustain on Bends
12-02-2006, 02:07 AM
guitarman13
Posts: 388 - iTrader: (
I'm having an annoying problem with my 2005 VWH. When I get a pinch harmonic on the third string and bend the string, the pinch harmonic fades out. The same thing happens when I try to get a pinch harmonic at the top of a bend. On the 14th fret, I can't get a pinch harmonic at the top of a bend at all, it fades out right away. This problem mostly occurs on the 9th fret up. What do you guys think the problem is? My setup? Why does this only occur on the third string?
guitarman13
Find all posts by guitarman13
12-02-2006, 02:18 AM
howe
Posts: 67 - iTrader: (
Re: 3rd String-Pinch Harmonics Won't Sustain on Bends
I had the same problem on my rg570. When i try to do the intro from "direct injection"(greg howe), the pinch armonic on the 4th fret doesn't come out or won't sustain!.
howe
Visit howe's homepage!
Find all posts by howe
12-02-2006, 06:31 PM
OLIE_ROCKS_THE_80'S
Posts: 2,770 - iTrader: (
Reviews: 10
This is indeed a weird issue!!! I have the same problem in my RG550 and I have troubleshot it but I can't seem to be able to fix it, parhaps Rich the technical guru could enlighten us about this problem if he catches this thread!!!
OLIE_ROCKS_THE_80'S
Find all posts by OLIE_ROCKS_THE_80'S
12-02-2006, 06:43 PM
scotte_za
Posts: 592 - iTrader: (
i *think* this may have something to do with the problem known as "fretting out"
It has happened to me and when i raised my string height a little on my (crappy) epi SG special it seemed to fix it a bit, but im no tech guru so i couldnt eliminate it
just a thought
scotte_za
Find all posts by scotte_za
12-02-2006, 06:53 PM
OLIE_ROCKS_THE_80'S
Reviews: 10
scotte_za
just a thought
Nope, it has nothing to do with that really, because all bends and notes ring out and sustain clearly but when you put a pinched harmonic on top of the bend is when this phenomena occurs...
(Just for the record my guitar is perfectly set up and the frets are leveled)
OLIE_ROCKS_THE_80'S
12-02-2006, 07:39 PM
Lefty Robb
Posts: 4,930 - iTrader: (
could be the way your hitting the harmonic, I've noticed if I hit them lightly they ring better. are you also compensating for bridge pullup?
Lefty Robb
Find all posts by Lefty Robb
12-02-2006, 08:04 PM
OLIE_ROCKS_THE_80'S
Reviews: 10
Lefty Robb
Sorry Robb but that's not the issue either! I learnt to do P.H. 16 years ago and I can assure you I am pretty good at it!!!
(all kidding aside this does not happen with any other of my guitars...?!?)
OLIE_ROCKS_THE_80'S
12-02-2006, 10:05 PM
howe
YEAH, the bend P.H(4th fret, 3th string) in my squier sustain better than in mi rg570.
an ibanez issue???
howe
12-02-2006, 10:25 PM
Randy Rhoads
Posts: 318 - iTrader: (
The distance of of the pickups is making resonance with the mangnetic field on the frequency of the harmonic, canceling it...
Lower as much as you can the Pups and try again...most probably your harmonics will have a lot of sustain, ,then raise the pups and when the sustain fails, backup a little.....
my .02
Randy Rhoads
Find all posts by Randy Rhoads
12-02-2006, 10:32 PM
OLIE_ROCKS_THE_80'S
Reviews: 10
Randy Rhoads
my .02
Thanks for the suggestion!!! already tried that before and it was no use
OLIE_ROCKS_THE_80'S
randy rhoads
where can i get big bends nut sauce in Australia
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
MyHELP lack of good string muting is KILLLING ME!! - Fret ha
Triangle
Guitar Lessons & Music Theory
08:57 AM
Dead sounding string - G string has short sustain - possibly
BASe L
03:40 AM
Picking up the slack... - ...on that low string
mechanyx
02:23 AM
About Jem7V sustain - Jem7V sustain
Bati
02:15 PM
7 String Pick-ups... *Blaze Custom in Bridge? - Re-replacing
Acid Rainforest
Other 7-string Guitars
05:51 AM
01:33 PM
