Old 02-09-2005, 01:49 PM
Azrael  is offline
Posts: 403  -  iTrader: (0)
4 springs with 0.09
Can I use 4 springs with 0.09/0.42 strings on my RG3120 with Lo-Pro? I'm hoping to get a bit more sustain this way but I'm not sure if this is possible.
Old 02-09-2005, 03:41 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
Re: 4 springs with 0.09
yes. but you'll need to remove that little piece that holds the springs down. and you'll have to back off the spring-claw quite a bit. I don't know if it'll make a lot of difference in sustain.
you may want to try a hipshot tremsetter. but it'll change the feel of the tremolo.
Old 02-09-2005, 04:00 PM
SirLoyal  is offline
Posts: 49  -  iTrader: (0)
Smile
In my experience with strats, sustain in the springs comes in proportion to how taut, or stiff they are. Less springs pulled tighter, I believe, equals more sustain, although it doesn't do that much. A good way to tell is to scrape them with your pick. They slacker they are, the quicker they absorb vibration.
Old 02-09-2005, 05:00 PM
Azrael  is offline
I just fixed a problem that I have been trying to fix for a long time. I put 2 stiff springs in it and 2 less stiff springs. Now I have 4 springs with a standard 0.09 string configuration.
My sustain is has improved alot. It's more than twice as much. And I'm really not lying. Finally my notes ringout slowly instead of quite abrupt.
Just one little problem now. I can't use the little stringholder thing that you put on the strings normally since I have 4 springs now. I hope it doesn't cause any problems.
Maybe something (and I really don't know what) was wrong with a few of the older springs. My sustain has doubled and that should not be expected from a simple spring change. However......
I'm VERY happy with this!
Old 02-09-2005, 10:19 PM
Mo Fo  is offline
Posts: 30  -  iTrader: (0)
if you put 4 springs in there with 9's, you'll bottom out the tremeolo. That actually will give you great sustain, since the bridge will be touching the body. Especially if you yank out the little piece of rubber under the bridge.
Old 02-09-2005, 10:31 PM
john1880  is offline
Azrael. I took off all those little spring holders on about 5 RGs and never had a problem, so I wouldn't worry about it.
Glad you got the problem fixed.
Old 02-10-2005, 01:18 PM
Azrael  is offline
Nono.....I didn't just put another one in. I adjusted the bridge after it ofcourse....
I ain't that stupid.....
hipshot tremsetter
Anyone here using 3 52mm springs in V config /|\ ? Dr Mindcrime Tech: Setup, Repairs and Mods 1 09-27-2004 10:39 PM
Trem springs on 7vwh wont hold 10s... red5 JEM and Universe Guitars 10 03-16-2004 11:21 PM
Offset 4 springs dex Tech: Setup, Repairs and Mods 1 02-17-2004 07:41 AM
JEM 7DBK - why 4 trem springs? pseudomarine Tech: Setup, Repairs and Mods 1 02-20-2003 09:31 AM
Stretching springs.... leishan Tech: Setup, Repairs and Mods 1 02-13-2003 07:58 PM
