Old 05-25-2007, 08:20 PM
ohioplayer  is offline
Posts: 265  -  iTrader: (6)
5 Way Switch Help
If this was a standard strat style, I would understand and know how to wire it. but I have never seen a 5 way like this and am hoping someone can give me some ideas/help on how to wire this thing:
The pins read in order as follows (in the photo) starting left to right on the top row:
6 2 3 7 - top row of pins
4 1 5 - bottom row of pins
I do not know what guitar this came out of. I was going to put in a strat style but I liked the look of this one and it fits the cavity like a glove.
Any help would be appreciated. Thanks in advance.
Old 05-25-2007, 08:33 PM
buddroyce  is offline
Re: 5 Way Switch Help
I have no idea, but if you want to figure it out, just use a multimeter to map out the switch. My suggestion is to just get a better constructed CRL switch. It'll be a better switch in the long run.
Old 05-25-2007, 08:44 PM
The Official Fender Brand 5 way I bought didn't want to fit and I was not going to force it. This was the only one out of my pile that fit with no issues. Are the 5 ways on jems different in size?
Old 05-25-2007, 09:11 PM
It looks like a variation on an Import YM-50 type switch. Usually the CRL switch(the original Fender type) will fit, except the screws are bigger. I had this problem once, but then I realized that the difference was negligible and the screws will tap a hole wide enough when you screw 'em in. I've swapped out the switches on my J-Customs and my Universe out and had the CRL switch installed simply because I like it better. (that and I can mod how smooth the switch can be on the CRL's).
Old 06-02-2007, 01:24 AM
Got the Fender to fit. Thanks for the info.
strat style
How to wire up a special 5-way switch? bduersch Pickups & wiring 7 08-15-2006 09:00 AM
YM-50 Switch! Little Fighter Pickups & wiring 3 12-19-2005 04:50 PM
Jpm Switch Observations.... slagaxe Pickups & wiring 2 11-19-2005 12:57 PM
After adding a push/pull switch... cowcowcow Tech: Setup, Repairs and Mods 3 03-26-2002 08:39 AM
Different 5-way switch - why are they different? cowcowcow Tech: Setup, Repairs and Mods 7 03-17-2002 03:45 PM
