Old 06-26-2007, 09:54 AM
djhollowman  is offline
Posts: 36  -  iTrader: (0)
6 string and 7 string RG bodies same size??
Hi all,
Can anyone tell me if the body size for a 7-string RG body is the same overall size as a 6 string equivalent, or is the 7-string wider?
I realise there will be differences in the neck pocket, bridge position, pickup position etc, but I'm asking if the OVERALL dimensions are the same? Eg, the total length, the total width, the shape of the horns.
This isn't why I'm asking BUT...for instance, with modifications, could you attach a 7-string neck to a 6-string body?
Also, anyone know where I could get a blueprint or a plan for an RG (or v.similar) body shape?
Greatly appreciate any help!
DJ
Have since found some info here:
http://www.jemsite.com/forums/showthread.php?t=2319
but would still appreciate anything helpful!
Old 06-26-2007, 11:44 AM
jim777  is offline
Re: 6 string and 7 string RG bodies same size??
I have a 550 and a 7620 body at home; I'll lay one on the other when I get home and check for you on the size. Since the routes down the middle are centered (pickup cavities, trem cutouts, neck pocket) you would need to expand all the routes on both sides and top and bottom, not just make them wider on one side.
Anyway, I'll let you know tonight if they are the same size. As has been stated, they very likely are identical, as that would cut the cost of body blanks for Ibanez (by not requiring any new wood, just a different CNC route).
jim
Old 06-26-2007, 12:45 PM
Out Of This Swirled  is offline
Posts: 926  -  iTrader: (1)
Images: 7
hi daz this may help its is my soon to be dipped rg7620 sitting on top of my soon to be dipped rg570, their a pefect match!
this was news to me! i thought the 7 string body was also slightly wider, but i is thikk! lol
Old 06-26-2007, 01:08 PM
courtney2018  is offline
Posts: 1,270  -  iTrader: (4)
Reviews: 16
Go to this link and scroll down to the very bottom where you'll find JEM blueprints.
http://www.jemsite.com/jem/origin/index.htm
Old 06-26-2007, 01:38 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
yep, they match perfectly.
Old 06-26-2007, 03:10 PM
twooos  is offline
Posts: 660  -  iTrader: (1)
so a 7 string neck wont fit onto a 6 string neck route?
Old 06-26-2007, 03:13 PM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
No, they are wider. About 1 string wider in fact.
Old 06-26-2007, 03:16 PM
twooos  is offline
Ok that was a pretty stupid question...
but could i get a 6 string neck pocket routed that "1 string" extra?
then i could get a 7 string neck??
Old 06-26-2007, 09:20 PM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
yes but you'd have to fill and redrill the screw holes in the body, and route the neck pocket wider and route the pickup and bridge routes wider too of course.
Old 06-26-2007, 09:43 PM
quiksilverdew  is offline
Posts: 668  -  iTrader: (0)
In other words...Not worth it...
Old 06-27-2007, 01:49 AM
StoneLord  is offline
Posts: 113  -  iTrader: (0)
From Projectguitar
Ibanez Rg 6 To 7 String Conversion, A quickie project:
http://projectguitar.ibforums.com/in...howtopic=27107
From the thread:
"The screw holes in the 7-string neck I bought even line up with the holes on the 6-string body."
Old 06-27-2007, 02:14 AM
cool, definitely do-able then
Old 06-27-2007, 03:51 AM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
Doesn't really seem worth it as you'd also have to replace almost every piece of hardware on the guitar while you were at it. Probably cheaper, and a lot less hassle to source a used Ibanez 7 String and modify it to do whatever you need it to do?
Old 06-27-2007, 06:43 AM
Excellent info here people, I thank you all!
Esp. useful to see the two guitars actually placed on each other, that pretty much confirms it then eh??
(Nice socks btw Alan!)
DJ
Old 06-27-2007, 06:49 AM
Not according to the thread here:
About halfway down the first page he says:
"The screw holes in the 7-string neck I bought even line up with the holes on the 6-string body.", but maybe that was just due to the exact combination of parts he'd sourced, I dunno!
DJ
body shape, bridge position, pickup cavities
RG body vs. RG7 body - size difference? chilln2music Other Ibanez Guitars (including Premiums) 10 10-22-2009 02:40 AM
Major Help! String Clamp Won't Budge! Rekuss Tech: Setup, Repairs and Mods 9 02-24-2007 07:57 PM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha Triangle Guitar Lessons & Music Theory 3 05-31-2005 08:57 AM
RG VS. VB * - please help me guys ChrisReedSmith Other Ibanez Guitars (including Premiums) 2 02-14-2002 06:18 PM
Ibanez RG with hardtail? - high quality RG with no trem?? shask Other Ibanez Guitars (including Premiums) 11 04-09-2001 11:16 PM
