Old 06-03-2008, 01:06 PM
eruji  is offline
Posts: 81  -  iTrader: (0)
Re: 89 540S Project
Look what i picked up yesterday...
The first one i made the grain looked crooked on the headstock. So the next one I layed the neck down on the piece of veneer so that the neck was straight up and down with the grain, then rocked up the neck until the headstock was flat against the surface. Traced it out and cut leaving about 1mm of material around the trace.
Next I layed a piece of white paper butt up against the fretboard and did a relief sketch of the truss rod pocket and the screw holes.
Then I thinned out some wood glue and brushed it on to the head and applied the veneer.
I tried clamping it in between two pieces of wood at first and after about 20 minutes checked it and realized the the edges were not adhering because they are kinda rounded off. So i setup this high-tech device, basically a soft rag with some weight on top to help bend the veneer around the edges.
Let it dry overnight and did a quick sanding to remove the excess material on the sides.
I think this is going to make the headstock look much better with the new finish on the body. Thanks for the tip FrankFalbo!
Old 06-05-2008, 09:20 AM
Tubarão Guitars  is offline
Posts: 3,965  -  iTrader: (0)
Images: 3
Re: 89 540S Project
gonna rock!
Old 06-05-2008, 02:25 PM
eruji  is offline
Re: 89 540S Project
Okay here is the headstock after a couple coats of tung oil..
i used my dremel and a drill bit to rout the holes for the tuner pegs and the truss rod nut.
Here is the body after about 10 minutes of using the dremel to sand the horns round and 30 minutes of fixing what the dremel gouged out with sand paper
ready to finish...
First coat of tung oil...
Old 06-05-2008, 02:38 PM
eruji  is offline
Angry
Re: 89 540S Project
Okay, im hit my first major snag. I was checking the neck for straightness by laying a ruler on it with zero tension on the truss rod (the nut was just loose) and it had some forward bow on it. I thought well, let me just tighten the nut a bit to see if i can bend back, closer to straight. When i gave it a couple of 1/4 turns i heard a pop. At first i thought it was the hairline crack on the fretboard, but then looked around the back and it was the neck joint that i had glued. Looks like half of it had slightly re-cracked. Its not as bad as it was, but i didnt expect this to happen. I used an aliphatic resin glue which should be strong enough for this kind of repair.
So im going to have to re-open this crack and glue it again..
Old 06-05-2008, 03:05 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Re: 89 540S Project
Damn that sucks... what about a new neck? maybe you can snag one on the bay cheap if you keep looking, or here in the forum... thats awesome work you did on the body to be always worried about the neck recracking...
Old 06-05-2008, 09:17 PM
sleepyone  is offline
Posts: 150  -  iTrader: (0)
Re: 89 540S Project
THAT LOOKS SOOOOOOOOOO GREAT MAN!!!!!!!!!!!!!!!! Congrats!!!!!!!
Hope you get the crack thing solved!!!
And keep those pics coming please!!!!! hehehehe
Old 06-06-2008, 02:28 AM
jazzedout  is offline
Posts: 671  -  iTrader: (5)
Re: 89 540S Project
How many pieces is the body? Is it 2 pieces or 3? Thinking of doing the same to my S but I am worried what I'll find underneath...
Old 06-06-2008, 12:39 PM
eruji  is offline
Re: 89 540S Project
two pieces: body and neck
i did another coat of oil last night and painted the cavities with the shielding paint. ill post pics later...
Old 06-07-2008, 05:22 AM
Re: 89 540S Project
Maybe I didn't ask correctly, but how many pieces of wood is the body only. No Ibanez body that I know of is one piece. This body has very straight mahogany lines, so it is difficoult to see from the pics, but it should be made of 2 or 3 pieces of wood glued toghether. As I see it there is one joint right above the pickup routes (parallel to the woodgrain), but is there another one?
For instance my RG7620 is 3 piece body as can be seen here:
Mahogany is much harder to see...
Old 06-07-2008, 07:48 AM
eruji  is offline
Re: 89 540S Project
jazzedout:
i thought that was a strange question... i guess i should have read it more carefully :-) As far as i can tell its one piece, but the grain has a lot of stripes so i could be wrong. It might be just really hard to tell.
Old 06-08-2008, 11:15 AM
eruji  is offline
Re: 89 540S Project
Okay,
jazzedout i DO think its a three piece body. After taking a closer look it seems the middle section of the body had a different grain from the side pieces.
Here is the body after shielding paint...
backside
ready for electronics!
but first some closeups of the finish...
Old 06-08-2008, 04:06 PM
D.Vial  is offline
Posts: 221  -  iTrader: (0)
Re: 89 540S Project
Looks really nice, but I think that the headstock needs an Ibanez logo
Old 06-08-2008, 04:40 PM
kspeed  is offline
Posts: 215  -  iTrader: (0)
Re: 89 540S Project
Looks brilliant! Excellent work! How'd you get around the recracking of the neck? And I agree with D.Vial, the headstock looks a little naked with the logo
Old 06-08-2008, 10:23 PM
eruji  is offline
Re: 89 540S Project
I agree, i just dont know what to get or where to get it. Waterslide or Vinyl? what do you guys think? considering the oiled finish...
Messing with the truss rod was probably a bad idea. When i think about it now it seems a bit foolish to try to make the neck bend when it had no tension on it. Once i let off on the nut the crack aligned back to smooth again. So i figured i would just put the guitar together and see how bad the neck crack is under tension. So i did and my neck had quite a bit forward bow without tension, but it was still very playable after i put the strings on. So im slowly adjusting the truss rod, its close to where i want it, but im experimenting with how low i can bring the action down.
So the neck and crack is smooth right now. I want to see how much i can adjust before it starts to show again. Eventually i will reglue it but I just wanted to get this project finished for the time being.
Old 06-08-2008, 11:46 PM
Re: 89 540S Project
Beautiful, plain beautiful
CONGRATS!!!!!!!!!
clear coat, neck angle, neck pockets, playing guitar, sharktooth inlay, steel wool, trem block, truss rod nut, tung oil, wiring diagram
Steve Vai Flame Project...Someone Help me with this! metalgod72 Classified Ads: Guitars and Gear 3 04-20-2008 03:02 PM
Ibanez PGM30 / Telesavales Hybrid Project. CaptainEO Tech: Setup, Repairs and Mods 29 02-17-2008 10:28 PM
FS: Ibanez S Project LNG: Im washing my hands of it ibanezcollector Classified Ads: Guitars and Gear 15 01-04-2007 12:34 PM
Project #3 underway screamndemon69 JEM and Universe Guitars 20 11-16-2006 02:04 PM
WTB: Beaten/Played Jem for restore/custom project Devo Classified Ads: Ibanez JEM/UV Guitars 0 05-17-2005 01:34 PM
