Old 06-11-2008, 12:47 PM
eruji  is offline
Posts: 81  -  iTrader: (0)
Re: 89 540S Project
Just thought id update this thread with some more photos
Here are the new electronics installed (new 500K pots and i took apart the 5 way switch and cleaned it out)
The backplate for the electronics already had an aluminum covering, so i just needed to cover the trem backplate. A glue stick and some heavy duty aluminum foil did the trick!
Everything soldered together (the ground wires show in the pic below are incorrect, i thought you were supposed to ground to the wall but realize now that it goes straight to the output jack)
*forgot to mention that i did not wire the tone pot, i wanted to hear how it sounds, hard to say but i think it sounds brighter.
Old 06-11-2008, 03:18 PM
Nick 6  is offline
Posts: 62  -  iTrader: (0)
Re: 89 540S Project
Nice work, did you do any finish sanding between or after applying the tung? I'm almost done my saber, but after seeing the pics, yours has a nicer sheen to it and I'm trying to get a like finish.
Old 06-11-2008, 04:50 PM
eruji  is offline
Re: 89 540S Project
No finish sanding.. i just sanded the body down to 400 grit and applied tung oil with some paper towels. I did the tung oil three times total and thats it. I waited 24 hours between applications.
Old 06-13-2008, 06:37 AM
nienturi  is offline
Posts: 671  -  iTrader: (0)
Re: 89 540S Project
Very cool work, dude Looks awesome...
Old 06-13-2008, 07:55 AM
Zoot  is offline
Posts: 881  -  iTrader: (23)
Images: 98
Re: 89 540S Project
Brilliant job . I was going to say leave it as it is but after seeing how it looks now.....
How much does a Saber go for these days ?
Old 08-20-2009, 03:49 AM
lerxst6  is offline
Posts: 339  -  iTrader: (13)
Re: 89 540S Project
That is absolutely stunning. Nice work on the refinish, and adding the headstock plate is an awesome touch. Good stuff!!
Old 08-20-2009, 09:57 AM
andrewgosline  is offline
Posts: 312  -  iTrader: (0)
Re: 89 540S Project
the wood is really nice. Shame it was covered up by the paint in the first place I think you got really lucky with how straight and consistent the grain is! Very impressive. You've really worked hard on that.
Old 08-21-2009, 01:05 PM
nafigator  is offline
Posts: 389  -  iTrader: (0)
Re: 89 540S Project
this reminds me about my ongoing les paul project... awesome job man! like to see more threads like this!!!!
clear coat, neck angle, neck pockets, playing guitar, sharktooth inlay, steel wool, trem block, truss rod nut, tung oil, wiring diagram
Steve Vai Flame Project...Someone Help me with this! metalgod72 Classified Ads: Guitars and Gear 3 04-20-2008 03:02 PM
Ibanez PGM30 / Telesavales Hybrid Project. CaptainEO Tech: Setup, Repairs and Mods 29 02-17-2008 10:28 PM
FS: Ibanez S Project LNG: Im washing my hands of it ibanezcollector Classified Ads: Guitars and Gear 15 01-04-2007 12:34 PM
Project #3 underway screamndemon69 JEM and Universe Guitars 20 11-16-2006 02:04 PM
WTB: Beaten/Played Jem for restore/custom project Devo Classified Ads: Ibanez JEM/UV Guitars 0 05-17-2005 01:34 PM
