Old 04-07-2009, 07:30 PM
Alopikal  is offline
Posts: 4  -  iTrader: (0)
Question
A few questions about my S520EX
Hello.
This is my first post here, this seems to be a great site.
Alright, down to business... I recently restrung my S520EX and would like to fix a problem that's been bugging me for a while. The action of my guitar's higher frets are higher than I would like them to be, but the action at the lower frets is alright, although I have a little buzzing at the 1st to 3rd frets. I have my bridge set up at the correct angle, and I have lowered the bridge in hopes to fix the hightened action at the higher frets, but that hasn't done much.
Would I be able to correct this problem by adjusting the truss rod?
And if so, I have another problem... Two of the screws that are used to keep the truss rod cover on will not come out. They turn, but will not come out so I think they are stripped. How should I go about fixing that problem?
Thanks in advance, and sorry for the book-like post.
Old 04-07-2009, 09:40 PM
benhal9  is offline
Posts: 49  -  iTrader: (0)
Re: A few questions about my S520EX
Needle nose plyers for the screws. As for the neck, the truss rod needs adjustment as well as the neck.
Old 04-07-2009, 10:16 PM
Alopikal  is offline
Thanks for the reply.
What about the neck needs to be adjusted apart from the truss rod?
Old 08-20-2009, 07:09 AM
crossbones  is offline
Posts: 107  -  iTrader: (0)
If you getting buzzing on the first 2-3 frets when you lower the action at the bridge, you will probably also need to shim the nut to raise it slightly. I think I wil need to on my S520EX.
S520EX how to
how good are S520EX
S520ex Dee Other Ibanez Guitars (including Premiums) 16 07-28-2010 06:52 AM
FS/FT: S520EX w/ EMG 81/85 Dewy Classified Ads: Guitars and Gear 0 10-13-2008 12:13 AM
S520EX EMG HELP reiss_joel Other Ibanez Guitars (including Premiums) 0 05-28-2008 06:39 PM
FT: S520EX kirk Classified Ads: Guitars and Gear 5 12-09-2006 07:31 PM
s520ex smkin_guitar Other Ibanez Guitars (including Premiums) 8 08-31-2005 12:28 PM
