Re: a guitar neck?
That's not an easy question to answer. Tight enough but not too tight. They need to be pretty tight ... enough that there isn't any flex in the joint. You just have to do it by feel. And listen to the wood. If it's cracking, you are too tight. If you are stripping the screw heads, you are too tight.
This question has been answered here before. Do a search.
