Tech: Setup, Repairs and Mods
A problem with '89 FP intonation.
08-26-2007, 08:27 AM
Ad_Astra
Posts: 570 - iTrader: (
So, I've been fighting with the intonation of my 77FP for a long time. Just can't get it right. I've adjusted everything I've dared but still. The problem is with the
higher strings
. Notes sound good below the 14th fret but out of tune above it.
I've set the intonation for the 12th fret. But the intonation on 19th fret is bad. The fretted note is lower than the harmonic. The guitar stays well in tune and while strumming chords etc it sounds good. But when soloing over the chords it sounds terrible. It really is a pain in a55 when recording. And I HATE correcting the intonation with floyd roses..
What to do? I've adjusted the saddles, the
truss rod
and changed the springs.
Here's a photo:
http://ameba.lpt.fi/~vilkmati/Sontaa/DSC00300.JPG
Suggestions are welcome!
Ad_Astra
Find all posts by Ad_Astra
08-26-2007, 02:42 PM
Jaden
Posts: 2,464 - iTrader: (
Re: A problem with '89 FP intonation.
Im a little worried about those trem posts.....
they dont look right at all....
the trem seems pretty worn, are the knife edges etc OK ? - when you use the trem does it always return to tune ?
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
08-26-2007, 02:53 PM
ibanezking
Posts: 531 - iTrader: (
Ad_Astra
So, I've been fighting with the intonation of my 77FP for a long time. Just can't get it right. I've adjusted everything I've dared but still. The problem is with the higher strings. Notes sound good below the 14th fret but out of tune above it.
What to do? I've adjusted the saddles, the truss rod and changed the springs.
Here's a photo:
You can tell just by looking that the High E & B strings and not positioned correctly
The B should be about 1mm closer to the pickups that the G
and the High E should then be about 1mm closer to the Pickups than the B
Max
ibanezking
Visit ibanezking's homepage!
Find all posts by ibanezking
08-26-2007, 02:55 PM
Ad_Astra
whatisshredding
Yepp. The guitar stays in tune when using the trem.
Once I tried normal-looking trem posts from another Edge I have, but for some reason they didn't fit in my Jem :-o
Knife edges are OK as far as I know anything about them!
Ad_Astra
08-26-2007, 03:15 PM
Ad_Astra
ibanezking
Max
Hey!
I tried that with my age old strings (sorry :-p). Moved the b-
string saddle
the way you suggested and the high e saddle a bit further away from the pickups. Works much better now! Guess I gotta get new set of strings and do it better again!
Thanks!
Ad_Astra
08-28-2007, 07:23 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
You should go to ibanezrules.com and check out richs post about setup, front to back, and while your at it, those are definitely not your original tremolo post, i would have those replaced. They may be the wrong size as well. Im curious what fret are you using to intonate the guitar by?
sniperfrommars1
Find all posts by sniperfrommars1
08-29-2007, 01:34 AM
Ad_Astra
sniperfrommars1
As I said, I tried the original
truss rods
, but they didn't fit for some reason. I use both 12th and 19th frets for intonation.
It seems to work very well now. Gotta spend some more time with the adjustements next time I change the strings.
I've read that ibanezrules' setup-guide.
Ad_Astra
08-29-2007, 02:01 AM
steve
Posts: 590 - iTrader: (
BTW: you shouldn't try to do intonation with dead strings - they won't read true. You'll tend to find that fresh strings put onto an instrument intonated using old dead strings will be going sharp on you...
steve
Visit steve's homepage!
Find all posts by steve
08-29-2007, 08:33 AM
Ad_Astra
Yes, I know. That's why I wrote my apologies in an earlier message
Ad_Astra
08-29-2007, 08:00 PM
steve
Sorry; missed that.
steve
09-26-2007, 03:17 PM
Ad_Astra
Changed the strings today. Actually I tore the whole guitar down to pieces etc. Now the intonation's 99,9% perfect and the FP sounds better than ever.
Ad_Astra
09-26-2007, 04:56 PM
shawn7v
Posts: 25 - iTrader: (
This is a simple problem...............BRING IT TO A PROFESIONAL!!!!!!!!!!!!!!! I would never mess with my jem.
shawn7v
Find all posts by shawn7v
09-27-2007, 03:15 AM
Ad_Astra
shawn7v
Nah... Why bother? It's better when you can do it by yourself. I mean, all kinds of repairing. It's cheaper and you learn how the guitar works.
Ad_Astra
floyd rose
higher strings
string saddle
truss rod
truss rods
how far off intonation in cents
how bad is 10 cent sharp within intonation?
guitar solo problem when recording
problem frequencies when mixing
intonation makes strings tighter?
intonation problem
mr.jem555
04:02 AM
Little intonation problem (RG470)
Spekko
12:34 AM
UV777BK Intonation Problem
Vegas_Blues
04:44 PM
String intonation - weird problem
carlos seo
09:13 PM
Intonation & tuning problem.
jetfixer
09:50 PM
09:45 PM
