Tech: Setup, Repairs and Mods
A Problem with a Squire Stratocaster
06-01-2008, 08:01 AM
Technetium
Posts: 22 - iTrader: (
My English is not the best, and I'm not that good in guitar vocabulary, so I'll use pictures.
This is one of my guitars, a Squire Stratocaster:
http://img220.imageshack.us/img220/6605/99407662bd6.jpg
Last week, I installed 0.010 strings on it, after a long time of using 0.009 strings. I did it myself, and I only installed them. I did no further setup. I stretched them, but I felt like I needed to stretch them again today, and I started from the high E. This is how I stretch the strings:
http://img207.imageshack.us/img207/9264/50723441sy7.jpg
I did almost nothing, and look what happened:
http://img207.imageshack.us/img207/4803/27902015qf0.jpg
I found the parts that were broken (of course, threw the broken string to the trash), and here they are:
http://img207.imageshack.us/img207/6811/80859368qe3.jpg
I guess they're supposed to go like this (only on the guitar, lol):
http://img220.imageshack.us/img220/2156/90310974jn1.jpg
1. Did I do anything wrong?
2. How can I fix this? Can I do it by myself?
Technetium
Find all posts by Technetium
06-01-2008, 09:54 AM
stratoskier
Posts: 770 - iTrader: (
Re: A Problem with a Squire Stratocaster
This is not a big problem. There was nothing wrong with the way you were stretching the strings -- it just appears as if the intonation adjustment screw was barely threaded into the saddle, so the added tension from the stretching caused it to pop off.
Before putting it back on, you need to be sure that the threads aren't stripped on the screw or in the saddle. Thread it in there to see how it feels. If that's OK, put it back together. If something is stripped, replacements for both the screws and the saddles are easy to find.
Also, from one of your closeups of the bridge, it looks like the intonation hasn't been adjusted properly (the saddles are almost all in a straight line, and I doubt that is right). You probably need to have a technician adjust the intonation. Also, with heavier strings, the truss rod will need to be adjusted. You might want to just take the whole thing to a tech and have him do a setup at the same time they reassemble the bridge.
Regardless, this is not a major problem so you can relax.
Bert
stratoskier
Find all posts by stratoskier
06-01-2008, 12:55 PM
Technetium
stratoskier
Bert
The screw fell a couple of days ago, actually, but nothing changed. I could still play.
Thanks for your help!
Technetium
squire strat
best stratocaster copy?
what color is best for a stratocaster
how to customise a stratocaster
what nut does my indonesia squire standard have?
compare squire vs strat
Double Edge Problem
aerocol
Pickups & wiring
10:26 PM
JCM2000 DSL100 volume swell problem
Joshka
Gear and Equipment
40
04-14-2004
06:49 AM
luxury problem...
jemke
04:10 PM
Problem with the neck of JEM10
heiko78
05:44 PM
Input Jack - ... anyone else got this problem?
Fabe
07:29 AM
06:54 AM
