Tech: Setup, Repairs and Mods
A smarter kill switch
08-11-2009, 02:42 PM
VBK-Shredder
Posts: 56 - iTrader: (
This looks good, certainly more aesthetically pleasing than a toggle switch !
The Shadow Kill Pot SH124.
.shadow-electronics.com/viewpro.html?lang_id=&id=266
Sorry I am still crippled on this forum and cannot post links yet. Just add “www”.
VBK-Shredder
Find all posts by VBK-Shredder
08-12-2009, 03:53 AM
littlephil
Posts: 422 - iTrader: (
Re: A smarter kill switch
22 Euro!? Thats a bit expensive since a momentary switch is about a dollar.
littlephil
Find all posts by littlephil
08-12-2009, 04:28 AM
Sickbean
Posts: 262 - iTrader: (
I've ordered one - I'll let you know if it's any good once it arrives.
Hopefully be able to get some full on Buckethead action going...
Sickbean
Find all posts by Sickbean
08-12-2009, 01:06 PM
Ayrton
Posts: 4,157 - iTrader: (
44
Review...
http://www.youtube.com/watch?v=866__QJg9LQ
Link
http://www.shadow-electronics.com/vi...ang_id=&id=266
Ayrton
Find all posts by Ayrton
08-12-2009, 03:27 PM
MicahC
Yeah, I just went to Radio Shack and got a momentary switch. It's basically just a little red button. I'll post pics later
MicahC
Find all posts by MicahC
08-12-2009, 03:39 PM
Sickbean
MicahC
To be fair, I did this at first and it lasted about a week before starting to crackle and not kill the output reliably.
Hopefully the Shadow will be a bit better. Not sure what Buckethead Himself uses tho.
Sickbean
08-12-2009, 05:32 PM
VBK-Shredder
Sickbean
Wow you’re keen !!
I was simply in the “contemplation” stage and you have jumped ahead !!
I will look forward to your review ! I prefer real players reviews over sales talk.
Thanks.
VBK-Shredder
08-12-2009, 11:07 PM
MicahC
Sickbean
Hmm, well I can say that my situation is different. I did the killswitch mod about a month ago and it still works like the first day. Maybe you did something wrong? I dunno.
Here's my pic. yeah, the button is a little lopsided, but I didn't see it until after I screwed in the pickguard and I didn't really wanna undo it all again
And yeah, I got bored and took a couple Sharpie markers to it.
MicahC
08-13-2009, 03:35 PM
indeedido
Posts: 215 - iTrader: (
I've destroyed countless toggle switches on my Les Paul over the years doing my Ace Frehley, in fact that is why I learned to solder. I went through so many! I'll definatly check one of these out. I don't want an added hole in my guitar, nor do I have another chamber in my paul to put one, so this is perfect. Anyone know if you would have to put one of these pots in both signal paths of the pickups? The Les Paul has separate volume controls, so I assume you would need to put one in both spots. Although I would only use it on the bridge pickup, so I guess I answer my own question. Put it there! LOL
indeedido
Find all posts by indeedido
08-13-2009, 04:50 PM
skins345669
Posts: 835 - iTrader: (
What's wrong with a normal momentary switch wired to short out the pups? This sounds a bit silly to me.
skins345669
Find all posts by skins345669
08-14-2009, 03:53 AM
littlephil
indeedido
I'm guessing its similar to a push/pull pot in that the killswitch part is separate from the pot itself, so it cuts the signal between the pots and the output jack, so it would work on both pickups. I dont know for sure though.
littlephil
08-14-2009, 04:34 AM
Sickbean
skins345669
This would require either drilling a hole in your guitar or removing a pot.
Hence the need for this.
Sickbean
08-14-2009, 03:09 PM
skins345669
Sickbean
I can see reason behind it, but it still seems excessive. I just replaced one of my tone pots with a two way switch and wired the other tone pot for for pups, for the price of a single switch.
skins345669
08-14-2009, 04:32 PM
MarkE
Posts: 469 - iTrader: (
Reviews: 15
skins345669
I went a similar route :
I never used the 2 tone controls independently and I only used the volumes independently for killswitch sounds, so it made sense when fitting the EMGs to wire it up for master volume/tone and stick a killswitch into one of the holes. I also moved the pickup selector as I got bored of hitting it by accident when getting carried away on chords.
At some point I might wire up another killswitch button in the old pickup selector position.
MarkE
Find all posts by MarkE
08-17-2009, 07:00 PM
skins345669
2 kills? The fun you could have with that...
skins345669
why jem super switch?
how to wire a 3 way strat switch
what is pu selector switch
how to install coil tap switch
how do i use the mono stereo switch on my guitar
Make a 5 way switch a kill switch?
GuitarEvan07
Pickups & wiring
03:19 AM
Swapping the tone pot for a kill switch. How do I do it?
GuitarEvan07
Pickups & wiring
03:17 PM
Having some problems wiring my kill switch.
GuitarEvan07
Pickups & wiring
07:49 PM
Would this work for Wiring a kill switch?
GuitarEvan07
Pickups & wiring
09:49 PM
kill switch
GreasyKid
Pickups & wiring
04:07 AM
08:27 AM
