Old 12-03-2007, 02:45 PM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
A thought regarding intonation
Hey folks,
Just a little thought concerning intonation - I'd like advice please if you have any.
The intonation on the high E on my two-year-old 2550 is a little out. The only other guitar I've ever adjusted intonation on is my Strat, which is a 22-fretter. The method I use is typical fayre; compare 12th fret harmonic with the fretted note etc. etc. etc. However, the RG is a 24-fretter, and I have never adjusted it before - I guess that says a lot for the set up at the factory!
My thought is this: I heard somewhere (possibly just an Old Wives' Tale, but I'm not sure) that it's better to measure intonation on a 24-fret neck guitar by comparing the harmonic/fretted note at the 24th fret instead of the 12th. Obviously it's the same note an octave up but will I get any better results intonating at the 24th rather than the 12th?
Like I say, just a thought!
'87
Old 12-03-2007, 05:40 PM
Codyyy  is offline
Posts: 68  -  iTrader: (0)
Re: A thought regarding intonation
I've heard that using the 24th fret is better because intonation becomes farther off the farther you go away from the nut... so I think that would be more accurate. But I'm not that sure.
Old 12-03-2007, 05:45 PM
jemplayer55  is offline
Posts: 2,627  -  iTrader: (0)
^^^^ Ugh..... wouldn't the twelfth fret be closer to the nut than the 24th fret? Plus, isn't the twelfth fret roughly halfway between the nut and bridge? Hmmm....
Old 12-03-2007, 06:32 PM
Codyyy  is offline
Yes.... which would make the 24th fret farther away from the nut, correct?
Old 12-03-2007, 06:42 PM
Read your own post again.... Do you know where the nut is? Not the bridge..... Besides, the best point to check intonation is at the center of the string length! I mean isn't that a critical measurement in guitar construction?! Hmmm....
Old 12-03-2007, 06:49 PM
Rich  is offline
The most accurate place to set intonation is at the last fret, unless you never play over half scale......
Old 12-03-2007, 06:54 PM
Davey  is offline
Posts: 4,783  -  iTrader: (21)
So last would be 24th yes?
And of course the 12th fret is closer to the nut than the 24th
Old 12-03-2007, 07:03 PM
Actually I thought setting it at the twelfth fret helped with chord voicing as opposed to setting it at the 24th fret. Especially since most playing is done below the twelfth fret. I'll agree it does help with upper register soloing but not much chording going on up there....
Old 12-03-2007, 07:24 PM
Rich  is offline
Maybe the way you play, Steve and Joe have to restrictions on where they "chord". You could definitely benefit from a read through a Peterson strobe manual where it will tell you that open and 12th is not an accurate way to intonate in the least, even with a strobe......
Using the last fret makes the whole board intonation better, it's not just a second scale benefit.
Old 12-03-2007, 07:50 PM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
I have noticed since intonation the way it is described on riches site that I got better tone and sustain.
Old 12-03-2007, 11:48 PM
Jeremiah  is offline
Posts: 39  -  iTrader: (0)
...wow...that makes since...i will forever intonate differently! lol
Old 12-03-2007, 11:51 PM
I'll have to give it a try..... oh, and my strobe tuner is a old Conn! So old it's got tubes! It's a old model ST-8. But it still does a great job for setup. Hey, will this technique will work on a 22 fret guitar also? Or just on my JEM and RG and other 24 fret guitars?
Jeez.... guess I'm just old school and behind the times! But I've never had intonation problems. It was explained to me that soloing in the upper register wasn't as much of an issue since most guitars were 22 fret. And since the frets were closer, finger placement directly behind the fret was not as critical to hit a note without sounding like it was out a couple of cents.
But your right.... I mostly use my Strats and rarely go beyond the 20th fret unless I'm playing slide.
BTW, Rich..... are you suggesting I use too many "pu$$y" chords?
Old 12-04-2007, 01:46 AM
Jeremiah  is offline
sounds like if you have a 22 fret you would just make sure your first string is tuned accurately to E and that the last fret is tuned accurately to D...i don't know why no one ever told me this method before lol
Old 12-04-2007, 04:31 AM
Rich  is offline
I'm just suggesting there's always a better mousetrap, somewhere.
Old 12-04-2007, 10:46 AM
Rich..... So can you tell there is a marked difference using that method on a 24 fret guitar? I mean is this something you can actually hear or see on a strobe or digital tuner?
Damn, now I want to change strings and do a fresh setup just to find out!
fret guitar, fret guitars, fret neck, strobe tuner
A question about intonation jeffrg270 Tech: Setup, Repairs and Mods 3 04-02-2005 07:42 AM
Lo Pro Edge intonation tool... Bluestreak Tech: Setup, Repairs and Mods 4 02-01-2005 04:26 PM
Where can I buy an intonation lock screw and washer? Mindcrime1204 Tech: Setup, Repairs and Mods 5 10-27-2004 06:06 AM
String intonation - weird problem carlos seo Tech: Setup, Repairs and Mods 10 06-22-2004 09:13 PM
Intonation adjuster - where to buy larsmars Tech: Setup, Repairs and Mods 5 07-13-2001 06:41 PM
