Old 11-16-2007, 11:20 AM
JasonMalmsteen  is offline
Posts: 122  -  iTrader: (0)
action.. please help
hey, my action was perfectly fine not too long ago.. I had my RG520 locked up in its case and stored away for a while.. I took it out yesterday to play and mannnn the action is terrible! I can like drop my pick through the space between the fretboard and strings with no problem at all.. how do I get my action back? I didnt touch it for a while so I didnt **** with anything.. please help!
Old 11-16-2007, 11:23 AM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
Re: action.. please help
...neck front-bow? did it stay in bad climatic conditions?
Old 11-16-2007, 11:26 AM
it was stored inside a case in my basement, im not sure if the temperatute changed alot.. btw. how much does neck bow effect the action? I believe that you are supposed to have a bit of relief right?
Old 11-16-2007, 11:34 AM
...if the bow is very pronunced you can have really bad effect on the action. One point more on the bow is that you said you didn't touch it for time, and didn't mention an inusual angle on the trem so...
try so, push a strung on the first and after the last fret, ouy should have a distance of around 0,8mm between the srting and the 12th fret
let us know
Old 11-16-2007, 11:36 AM
unusual angle? umm.. im not sure what you mean by that, before i stored it away it was set up all nicely with the trem angle all set n stuff, i didnt touch it for a while so I dont know..
Old 11-16-2007, 11:38 AM
btw, thanks for the help
Old 11-16-2007, 11:40 AM
if the trem knife is perpendicular to the pods than it's not a trem problem
Old 11-16-2007, 11:42 AM
pods? you mean like how if the knives are perpendicular to the guitar body? and umm so if it its that mneans that it is only the necks fault? thanks
Old 11-16-2007, 11:45 AM
sorry i meant studs, perpendicular to the studs, or parallel to the body
Old 11-16-2007, 11:49 AM
my neck looks almost or perfectly straight to me, is this a problem?
Old 11-16-2007, 11:51 AM
did you do what i told you? push the string and so on..? else you could post some pics of the guitar
Old 11-16-2007, 11:53 AM
no sorry, i will check it when I get home. I am on a public computer atm but i remember taking my guitar and looking at it straight up the neck
Old 11-16-2007, 11:56 AM
do it, you can't notice it only by spotting the neck unless the neck is wasted!!
Old 11-16-2007, 11:58 AM
ohh I see I thought you could just look at it like that :P hehehe
Old 11-16-2007, 11:59 AM
hmm.. so small changes can effect the action so much?
guitar body, neck bow
New RG3120TW... How low can the action go? vlad J-Custom, USA Custom & Prestige Ibanez Guitars 9 02-01-2003 03:57 PM
Action setup, used 3120 - I'm stumped dmike Tech: Setup, Repairs and Mods 8 05-02-2002 03:16 PM
neck shimming, buzz, no low action... what to do?!? - I can' berntsen Tech: Setup, Repairs and Mods 2 04-16-2002 05:34 PM
Action...how high or low? - where do you like diek Tech: Setup, Repairs and Mods 7 11-04-2001 10:31 PM
Edge and Lo Pro Edge problems after action change - I don't Kremlin Tech: Setup, Repairs and Mods 13 07-20-2001 04:34 AM
