Tech: Setup, Repairs and Mods
Action won't low, help!
05-23-2008, 08:43 PM
Rachmaninoff
Posts: 567 - iTrader: (
Reviews: 11
The previous owner of my UV7BK had 10's, and the action was pretty high, he used 4 springs. Now I'm making the setup with 9's, and I can't low the action as much as I want. I guess the bridge is too raised, but I'm not sure. I tried all the spring configs, with 3 and 4 springs, and the best was the 3-spring in arrow. 4 springs gave me almost the same result, but the whammy bar was too hard to pull. The trem posts are at the minimum. And I can't tight the springs anymore, see the pics:
The first thing that comes to my mind is a
truss rod adjustment
, but I need a pipe-like wrench, which I don't have, and I could not find one yet here in Brazil (can you believe it?). I'm still searching BTW.
So, what could I do in order to have a better action, under those conditions?
Rachmaninoff
Visit Rachmaninoff's homepage!
Find all posts by Rachmaninoff
05-23-2008, 10:43 PM
DarthLamer
Posts: 108 - iTrader: (
Re: Action won't low, help!
The bridge looks fine, maybe even set a bit too much into the body cavity. Depending on how much relief there already is, I'd suggest a truss
rod adjustment
as you had mentioned.
DarthLamer
Find all posts by DarthLamer
05-23-2008, 11:45 PM
bakerman
Posts: 65 - iTrader: (
If you give the neck a very slight amount of forward bow (or find it's already like that) and the action is still too high, you may want to consider placing a shim at the 24th-fret edge of the neck pocket. That would allow raising the posts and adjusting the
bridge angle
(for more pull-up range, as well as not being at the limit of claw movement with those 3 springs) while maintaining low action.
bakerman
Find all posts by bakerman
05-24-2008, 04:10 PM
JKD
Posts: 59 - iTrader: (
Won't forward bow raise the action slightly after you're done re-tuning/adjusting the
trem claw
to compensate?
JKD
Find all posts by JKD
05-24-2008, 05:58 PM
kspeed
Posts: 215 - iTrader: (
JKD
Won't forward bow raise the action slightly after you're done re-tuning/adjusting the trem claw to compensate?
Yes, and without pictures or measurements it's impossible for us to tell if he's got too much or too little. A proper setup would include a very slight forward bow.
Does your nut have any shims under it? Some guitars are fine with none and others need a few. Each is a little different.
kspeed
Find all posts by kspeed
05-24-2008, 06:56 PM
Rachmaninoff
Reviews: 11
I guess there is a shim under the nut:
Also, when I look through the holes of the nut (removing the screws), I don't see wood, I see white.
Should I umount the nut and remove this shim?
How's the process? Loose the 2 screws behind the neck with an
allen wrench
Rachmaninoff
05-24-2008, 08:16 PM
Tubarão Guitars
Posts: 3,965 - iTrader: (
Rachman, learn about the
locking studs
Im pretty shure this is what making your bridge in a high but not right action:
Some portuguese tutorial:
O problema que vc está tendo com os pivots é algo bem simples, mas como eu falava com um usuário aqui da comunidade ontem mesmo, é uma situação que MUITO POUCA GENTE sabe lidar!!!
Bom, não parece, mas dentro do pivot existe um OUTRO parafuso, que é chamado em inglês de
LOCKING STUD
Veja aqui, nesta foto, 2 pivots.
O da esquerda tem o Locking stud pra cima, desparafusado.
O da direita está sem locking stud.
Então, além do parafuso grande que regula a altura dos pivots, existe um outro parafusinho interno, que é regulado com uma chave beeeeeeeeeeem pequenininha, naquele furico quase invisível no centro do pivot, pela parte de cima, conforme esta foto:
e essa:
Na foto do diagrama do manual da ponte Lo Pro Edge, segue as partes, e os studs:
[manage]
E, pra complementar, o ângulo correto de inclinação da ponte, como vc já deve saber, é esse:
http://www.jemsite.com/tech/img/trem_angle_ibzlopro.gif
http://www.jemsite.com/tech/img/t_trang1.jpg
Bela guitarra!
HAGO,
Tubarão
Tubarão Guitars
Visit Tubarão Guitars's homepage!
Find all posts by Tubarão Guitars
05-24-2008, 08:19 PM
Tubarão Guitars
Sobre a chave de regulagem do tensor que vc perguntou, infelizmente é muito difícil de achar e no momento não possuo nenhuma sobrando.
Abraço,
Tubarão.
Sorry the mess, guys, let's get back into english, if anybody wants.
Tubarão Guitars
05-24-2008, 10:36 PM
TommyGuitar
Posts: 206 - iTrader: (
In my experience, you can make a
truss rod wrench
by taking a 7mm socket and grinding down the wider end of the socket if it doesn't fit in the
truss rod
hole (a lathe would be great, I used a bench grinder). Then you just drill a hole in the side of the socket and stick something in the to turn it. It's ugly but it will do.
TommyGuitar
Find all posts by TommyGuitar
allen wrench
bridge angle
locking stud
locking studs
pro edge
rod adjustment
rod wrench
trem claw
truss rod
truss rod wrench
how to get low action
how to set action on a Edge Zero Bridge
amalio burguet guitar has high action ?
neck what your low action jackson "24th fret"
ibanez s540 how to get low action
getting the lowest possible action
robbo12
11:05 PM
Action setup, used 3120 - I'm stumped
dmike
03:16 PM
neck shimming, buzz, no low action... what to do?!? - I can'
berntsen
05:34 PM
Action...how high or low? - where do you like
diek
10:31 PM
Edge and Lo Pro Edge problems after action change - I don't
Kremlin
04:34 AM
05:43 AM
