Old 07-15-2007, 09:02 AM
TequilaKing  is offline
Posts: 293  -  iTrader: (12)
Adding an image to a body
I have an stripped back RG body that I'd like to add an image too.
At the moment I have the image in a .png file (can easily be converted to .jpg, .bmp, .psd etc) and what I want to do is print it off, stick it on the body and then clear coat it...
Now the big question.... whats the best way to do this?
I was thinking of printing the picture off onto an ohp transparceny sheet, cut out the image, stick it to the body then clear coat / sand back / clear coat sand back / clear coat etc
Has anyone done this? If so any pointers etc would be great
Cheers
Old 07-15-2007, 01:26 PM
ohioplayer  is offline
Posts: 265  -  iTrader: (6)
Re: Adding an image to a body
The clear coat (when I tried this) removed some of the ink from the transparency. I haven't tried again since. There must be a decent way to do it though. I would like, as well, to see if anyone has some good suggestions on how to do this.
Old 07-15-2007, 02:09 PM
Salamander In The Sun  is offline
Posts: 859  -  iTrader: (4)
You could always print the image and make a stencil.
Old 07-15-2007, 02:19 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
I've used waterslide decal paper with my Epson printer, and have had great sucess. The inks on the Epson are pigment-based, instead of dye-based, so they are much more resistant to water whatnot. You just gotta make sure you add enough cleacoats to bury the decals.
Old 07-15-2007, 06:13 PM
projectjem  is offline
Posts: 664  -  iTrader: (0)
you could get it printed at a photographic shop like 12"x18", that'll be better and you could chose gloss or matt finish
Old 07-15-2007, 07:19 PM
Martallica  is offline
Posts: 342  -  iTrader: (1)
Here yea go ! I gave a mate of mine a pic and he printed it out on a sticker where he works .
The pic's should tell the rest of the store .
Marty...
Old 07-15-2007, 08:35 PM
Racerx2k  is offline
Mart, did you clear over it, or is it merely adhered? Looks good.
Old 07-15-2007, 08:59 PM
Clear over level sanded more clear wet sanded then compound .The sticker did shrink a bit so there was a bit of touching up .It's not that straight forward but wort the time.
Old 07-15-2007, 09:04 PM
stitch216  is offline
Posts: 22  -  iTrader: (0)
Better question, where did you buy a BattleTech comic?
Looks great.
This si the same principle behind the 'gravure' finishing that took off in the late 80's/early 90's, isnt it?
Old 07-16-2007, 09:09 AM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
find somewhere that can print your image on a self adhesive substrate using UV curable inks.
UV inks are a polymer and when cured they basically turn into plastic, I have cleared, varnished and encapsulated UV inks with no issues at all...
Old 07-16-2007, 09:25 AM
Cheers guys for the pointers most appreciated!
Old 07-16-2007, 09:42 AM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
I had the same idea Martallica had with the vinyl sticker and clear coat. It is nice to see someone tried it and had success with the idea.
I would like to try a Dali or Picasso print on one of my RG mutts but everyone I inquired about doing this won't touch stuff like that due to copyrights and what not. If I can ever land a Jagermeister endorsement for my band I'll get one refinished with a really cool Jager logo
Let us know how you fair TK if you do your own.
clear coat
jem body FOR SALE sims and christopher woods robthorn Classified Ads: Guitars and Gear 9 05-03-2007 09:08 PM
New Alder/Purpleheart/Walnut 7620 body jim777 Other 7-string Guitars 49 09-25-2005 08:05 AM
FS: "The Original" RG520NM, RG421, RG770 body gtrcollectr Classified Ads: Guitars and Gear 7 04-11-2005 01:24 AM
Exact JS body clone -- is it possible for a good luthier? gitarrero JS (Satriani Model) Ibanez Guitars 7 03-29-2003 11:36 AM
Wood choice for JEM - Before I order that custom body Jeroenn JEM and Universe Guitars 13 06-08-2001 01:14 PM
