Old 02-24-2003, 09:49 PM
track7  is offline
Posts: 351  -  iTrader: (0)
AGGH neck bolt wont tighten help!
High i never took a neck off a guitar in my life before...however my 7vwh needs a shim (action is super high even with bridge as low as possible but thats another story)...so i decided to try it out on my 7620 first incase i botch it.
So it all goes fine...however when i come to put the neck back on the bottom left screw (its an AANJ btw) wont go snug when it gets to the bottom it just keeps turning!?! I'm guessing this is bad. Is there anything i can do?
All the other screws are nice and tightly down...however this botom left isn't
i made sure all the screws went back in the holes they came from and was careful about keeping pressure on the neck whilst putting it back on.
Help please
track7
Old 02-24-2003, 10:15 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
Sounds like the hole is stripped. The best thing to do would be to fill it with some dowel and re-drill it.
Old 02-25-2003, 01:20 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
Yeah, the best to do would be to put dowel in, however, there are a couple of quick fixes too that work just as well.
First one uses toothpicks, same like out Cliplock strap buttons, but it requires more of them. put about 5 tooth picks in the hole, and glue them with white glue or instant glue, then put the neck back on, the screw should hold well.
Second is a very good fix, one I've done a few times. Mix up a batch of epoxy, but first, take the neck screw, and cover it in vaseline (not built up and gooey, just an even coat) Then, take your epoxy, and fill the hole completely. put the screw in, (screw it in like the threads were still there, dont' just push it in) let the epoxy harden, if you put the vaseline on well, the screw should pop and you should be able to unscrew it, don't force it though, the last thing we want is to strip the screw head. If it doesn't pop and unscrew, take a soldering iron, and put it on the head of the screw to heat the screw up (a lighter would work too, but will leave burn marks anywhere the flame touches) Don't make it hot enough to melt solder, but soon you'll start to smell the epoxy again, as soon as you do, get that screwdriver in there and remove the screw. Let the epoxy fully cool. You now have as close to a permanent thread in there as you'll ever have, and you don't have to worry about redrilling for a dowel and then hoping you get it all positioned perfectly again
Old 02-26-2003, 02:41 PM
GhesQi J  is offline
Posts: 221  -  iTrader: (0)
The mose elegant solution is already said:
redrill the stripped hole to fit a wooden dowel pin (diameter 8 or 10 mm). Use wood glue (titebond or similar) to glue it in.
If you are uncertain about doing this by yourself or if you do not have the right tools, you can choose a quick fix. (LGM's reply)
The mentioned fixes are already done by numerous people with succes.
Cheers,
Joten
cliplock strap, strap button, strap buttons
