Old 10-01-2002, 10:48 AM
shun  is offline
Posts: 2  -  iTrader: (0)
alternate tuning
about alternate tuning with the floyd rose...
Drop D and down 1 and 1/2 step
(B, F#, B, E, G#, C#)
how's the adjustment?
adjust the spring?
use heavier strings?
the neck?
THANKS!
Old 10-01-2002, 05:21 PM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
I'm pretty sure you won't have to adjust the neck unless you have an extreme low action to begin with. Even then you might consider leaving the neck alone and adjusting the bridge height if your already to low and start to experiance a buzz.
But chances are, your going to want to switch to a heavier guage of strings and also with that a slight adjustment to the springs to balance out your trem and bring it back down in the zone so to speak.
Old 10-02-2002, 08:14 AM
shun  is offline
Thanks!
In what situation, i need to block the tremolo bridge to lock out all movement?
alternate tuning, floyd rose, tremolo bridge
