Old 06-02-2006, 08:29 AM
Mintsoft  is offline
Posts: 5  -  iTrader: (0)
Another Floyd Rose Tuning/Return to Pitch problem
Morning all,
I was just wondering if someone can confirm my suspicions. My Floyd rose is all in tune etc fine, and if I use it to flatten notes etc its fine and returns to pitch. If I pull sharp with it, it'll end up about 15-20% sharp (according to AP Guitar Tuner). I was thinking its probably that the knifeedges are worn? I did buy the guitar secondhand and it looks pretty well used. I was going to sharpen the edges a bit but they're not flat ones, they're both like hooked and I dont really feel like trying to sharpen them. Anyway long story short, does anyone know if its gonna be a "buy a new floyd" job or what?
Thanks guys
Rob
Old 06-02-2006, 09:22 AM
Invictious  is offline
Posts: 4  -  iTrader: (0)
Re: Another Floyd Rose Tuning/Return to Pitch problem
Hmm, unless you actually have the patience and experience, go get a pro to fix it or buy a new floyd
Old 06-02-2006, 10:57 AM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Put it this way: If you f#*k it up, who cares. You were just about to sink money into a new trem, anyway, right?
Old 06-02-2006, 11:59 AM
Mintsoft  is offline
well thats what I was thinking tbh. But how on earth do you sharpen a curved surface like that I cant fathom it out! Maybe I'm being stupid or something. I'm hoping that someone will have a genius fix that'll mean I wont have to actually sharpen *prays*
Old 06-02-2006, 12:05 PM
Rich  is offline
Posts: 19,356  -  iTrader: (21)
The double curve could be the problem. If the studs aren't mounted perfectly centered to the radius it will always be edge binding. That's why the good Ibz trems have only one curved knife, the other is flat.
Old 06-02-2006, 12:27 PM
Rotti  is offline
Posts: 3,341  -  iTrader: (8)
You can sharpen it with a round file. I have one that is used for sharpening the teeth on a chainsaw.
Old 06-02-2006, 12:30 PM
ibanez2005  is offline
Posts: 910  -  iTrader: (0)
Check the nut, tune the guitar, lock the nuts down and press the strings one by one behind the nut. If the strings go out of tune then youve found the problem.
Old 06-02-2006, 01:16 PM
Mintsoft  is offline
Just tried that, the strings aren't slipping through the nut at all.
Also if I do end up looking for a new one, the best ones have one curved edge and one flat correct? Anyone know of anywhere in the UK that sells them?! I'd be nice to get a proper manufactured by Floyd Rose one, but I cant find a source for them anywhere
Old 06-05-2006, 04:43 PM
Trann  is offline
Posts: 3  -  iTrader: (0)
I wouldn't really reccomend getting an OFR, they don't have the 1 flat / 1 curved knife design. The arm design is also kinda lame IMO. I would reccomend getting an Edge or Lo-Pro from ibanezrules.com, the guy who runs that site is really good at setting up guitars and trems.
Old 06-05-2006, 04:55 PM
thebigugly  is offline
Posts: 147  -  iTrader: (0)
Good point. Only problem is that the edge trems do not directly retrofit on an OFR guitar. Have to redo the studs and cavity. If the trem has TRS anywhere on it to include the cheaper IBZ and Jacksons then get a new bridge. Even a sharpening will not help a TRS. Gotoh and OFR are the only ones i would consider.
edge trem, edge trems, floyd rose
RG350DX Floyd Rose Help ~ShOcKwAvE~ Tech: Setup, Repairs and Mods 29 06-14-2006 08:44 PM
FS: Original Floyd Rose & Floyd Rose 2 -zct- Classified Ads: Guitars and Gear 6 09-02-2005 04:07 PM
Original Floyd Rose or Floyd Rose Pro? Fatal-Tragedy Tech: Setup, Repairs and Mods 3 08-03-2004 10:56 PM
problem with licensed floyd rose slayer Tech: Setup, Repairs and Mods 6 03-17-2004 01:54 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
