Old 09-28-2006, 10:35 AM
SandmaN211  is offline
Posts: 118  -  iTrader: (0)
another fret buzz problem
hi everyone, i just changed the strings on my rg2570 and after a week i notice the first 2 strings are buzzing from E string=1st-11th fret, A string 1st-6th.
just wondering which way i should turn the truss to make the nut higher? im guessing the neck area on the low e/1st fret corner is starting to twist downwards hence making the notes on the E and A buzz.
i checked the relief and its about 0.5mm above the 7th fret so i dont think i need any more or less relief, i just want to make the nut area higher (if its possible)
any help would be appreciated
btw how much should i turn it say starting at 12 o clock
Old 09-28-2006, 03:47 PM
megawzrd  is offline
Posts: 203  -  iTrader: (1)
Re: another fret buzz problem
Get some half shims or cut a full shim in half (usually brass or stainless)...I think they sell em in .1, .2 and .3 mm thicknesses. Try the .1 half shim on your low E side to bring up the nut a bit.
Old 09-29-2006, 12:14 AM
is that all? i thought it was the necks problem
what do they look like?
Old 10-01-2006, 10:58 PM
megawzrd  is offline
On this very site in the setup section:
http://www.jemsite.com/tech/1setup.htm#step4
Old 10-02-2006, 01:53 AM
thanks mate :P
Check this out! How I fixed a buzz on 1 string, 1 fret john1880 Tech: Setup, Repairs and Mods 3 09-04-2006 07:20 PM
Fret buzz cures guitarsalad14 Tech: Setup, Repairs and Mods 5 08-28-2006 09:28 PM
Fret buzz, help me sort this please. SuperJemBoy Tech: Setup, Repairs and Mods 4 11-03-2005 12:19 AM
Fret buzz? Onizuka Tech: Setup, Repairs and Mods 4 09-06-2005 08:22 PM
JPM spring/bridge buzz problem Raffel Other Ibanez Guitars (including Premiums) 7 05-11-2004 05:20 AM
