Tech: Setup, Repairs and Mods
Any way to loosen up a tight volume pot?
10-17-2004, 01:34 PM
john1880
Posts: 468 - iTrader: (
Hi,
I have a RG3120. The stock volume and tone pots, which are much smoother than the stock pots in my RG570, RG520, are very tight. Not good for quick volume adjustments. Does anyone know if there is a way to loosen it up a bit. I already checked to make sure the Knob wasn't rubbing somewhere, and it isn't. They're just very tight compared to most others. I'm trying to avoid replacing it because it's a nice smooth audio taper, and some others don't have that nice taper to them.
Thanks.
John
john1880
Find all posts by john1880
10-17-2004, 02:46 PM
Algiman
Posts: 2,553 - iTrader: (
You tried a bit of contact cleaner in the pot? Some cleaners contain an inert lubricant, which may well do the trick for you.
Algiman
Find all posts by Algiman
10-17-2004, 03:11 PM
john1880
Hi Algiman,
I haven't tried that. Can you recommend a particular type? I have some electronic cleaner called Blue Shower, universal cleaner/degreaser. Do you think that will work?
Thanks.
John
john1880
10-17-2004, 06:15 PM
Algiman
I don't think I've ever bought the same brand twice! I had to use about 2 cans once to un-cease a
Les Paul
's controls - but you'll not need as much. You could try the stuff you have but I'd recommend one with lubricant.
Your local electronics store will amost certainly have something suitable - go explain what you need and see what they come up with.
Algiman
10-17-2004, 08:23 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Radio shack brand comes with the lubricant but its the only kind that Ive gotten a chance to try out. It made the volume pot on my 520 so smooth, that you can literally spin the knob without physically turning it. its my main guitar for doing volume swell tricks now. I wouldnt expect this type of reaction though but it will smooth the pots up. It will also clean out any unwanted scratchiness as long as the pot isnt on its last leg.
sniperfrommars1
Find all posts by sniperfrommars1
10-17-2004, 09:03 PM
john1880
I'll stop by a Radio Shack tomorrow. That should help the situation. If it's still too tight I'll just end up putting in a different pot, but I don't think I'll have to. Thanks guys.
john
john1880
10-19-2004, 09:47 PM
sniperfrommars1
I forgot to mention of you have your volume knob too low on your pots they will rub a little bit on the nut, and cause some friction slowing it down a little. Volume swells are a huge part of my playing and I know how frustrating crappy pots can be. I know several guitarist who use no knobs on their pots because they like a stiff feel there. Its all apples and oranges I just like being able to use my pinky to control the volume and still pick
sniperfrommars1
10-23-2004, 03:20 PM
john1880
I got it loosened up a bit by spraying some of that stuff in there and just working it back and forth for a while. still not as loose as the others, but it's usable for volume swells now. THANKS GUYS.
john
john1880
10-25-2004, 12:01 AM
nocluejimbo
Posts: 173 - iTrader: (
does anyone know how to make them stiffer? my Strat's knobs adjust too easily and often find myself at half volume wondering how it got there and why my tone was muffled.
nocluejimbo
Visit nocluejimbo's homepage!
Find all posts by nocluejimbo
10-25-2004, 01:15 AM
john1880
what i did with my tone knob was took the knob off, then put a littlt piece of foam around the pot, then put the knob back on. i want my tone all the way up all the time so that worked for me on one guitar.
or crazy glue
john
john1880
10-25-2004, 01:49 AM
Elysian
Posts: 324 - iTrader: (
sniperfrommars1
the pot i put in my RGT42 that came out of my 90 RG570 is like this... its always been like that lol... i like it, but sometimes it might be a little too fast lol
Elysian
Find all posts by Elysian
10-25-2004, 02:26 AM
john1880
I guess it's hard to fing good pot these days.
somebody had to make a "pot" joke sooner or later.
the pots that ibanez uses in the RGs up to the 570(the newer ones anyway) just go from zero to 10 too fast. tough to do a volume swell with. i usually replace mine with normal size pots that i get from stewart macdonald. but the one on my RG3120 is different from the other RGs. It's got a nice taper, but until I loosened it up, it was too tight for me. I like to turn the volume down whenever I don't play for more than a few seconds.
My friend once had these Allen Bradley pots that were awesome! They had a great feel, and the smoothest taper I've ever heard. But I don't see anyone selling them. Allen Bradley may be out of business or something.
john
john1880
les paul
how to loosen tension on ibanez RG350DX bridge
how to get a nice tight distortion
how tight tremolo arm
why guitar tight string tension?
do i hold the pick tight when i sweep pick
12:44 AM
